Problems with Stamp 2 software code
I am using two Parallax stamp 2 chips to go from ....input parallel to serial and then back to parallel. the code I am using is:
SER OUT
1) loop:
2) serout 16,84+$4000,{ins.low byte,ins.high byte}
3) pause 1
4) go to loop
SER IN
1) dirs-$ffff
2) loop:
3) serin 16,84+,{outs.lowbyte,outs.highbyte}
4) pause 1
5) go to loop
My problem is looking at the serial train on a digital scope there is a gap between bit 7 and bit 8. I want a constant serial train counting from 0 to 15 in order. Is this possible?
SER OUT
1) loop:
3) pause 1
4) go to loop
SER IN
1) dirs-$ffff
2) loop:
4) pause 1
5) go to loop
You should never have a PAUSE on your SERIN statement. Also I would slightly increase the PAUSE after the SEROUT to 100 and see if that helps. With those values being equal it increases the chances that the receive side will miss data. I would remove the PAUSE from the receive side completely.
