Spinneret on Activity board + XBee WiFi module
Seems like it should be pretty straight forward. Haven't looked into it yet but thats where I'm headed. The activity board has everything you'd need. Anyone attempt this with any luck?
I'd like to run a very basic web server using the XBee WiFi module on the activity board. It looks like the Spinneret is coded specifically for the WizNet series of Ethernet modules. I wanted to know if anyone has any resources on how to interface the XBee Wifi with the web server part of the Spinneret. I know the WizNet is capable of opening several sockets (I believe 4) simultaneously. Is this possible on the XBee WiFi? And if not, is this a limitation which will not allow the XBee WiFi to function as part of a web server?
Marcus
http://www.digi.com/support/forum/37564/getting-xbee-wifi-module-work-correctly-tcp-mode-with-browser
