Optical interrupter connections
I trying to use a Honeywell HOA6991-L51 device with the Prop development board. (P/N 32111).
I have connected the device per the datasheet (at least I think I have) as follows:
Red - IR diode anode (+3.3vdc)
BLK - IR diode cathode (ground)
Grn - Goround
Wht - VCC (+5.0vdc)
Blue - Output. Pin 20 on the prop pulled up to 3.3vdc via 300 ohm...at the junction of the collector and pin 20
It makes no difference if the path is open or clocked the output side remains at or near ground the the pin 20 side remains at 3.3 vdc. By the way I removed the connection to pin 20 and no change..
Anyone see the flaw in this setup??
Mike B.
Grn - Goround
Wht - VCC (+5.0vdc)
Mike B.
Next, 300 ohms seems quite stiff as a pull-up resistor, unless you need a very fast response.
Finally, what are you blocking the IR path with? Often, things that seem opaque to the human eye are transparent to IR. Try using a thin piece of metal to make sure you're blocking the path.
H
