Propeller Project Board USB revision — Parallax Forums
JkaneJkane Posts: 113
edited 2014-08-08 14:24 in Propeller 1
Hello,
I'm not sure if this is the correct spot for this, if it is not i will remove it and place it where it should be.
I am using propeller project boards for my development but there is this message on the link to the board
link http://www.parallax.com/product/32810
"This product is currently under revision. We expect to to stock the board again in the future."
I was wondering if there is an estimated date for re-release?
regards
Jeff
  • PropGuy2PropGuy2 Posts: 367
    edited 2014-08-02 08:26
    See also the post on Project Board of 7-11-2014 number #16 icon1.png Re: Project Board
    The product is under revision. It is not discontinued.
    There are two changes. First, two diodes were specified for much less current. Next, there was a VGA signal trace too close to the clock trace, causing VGA display issues. Using the VGA circuit was interfering with the Propeller's clock circuitry.
    It's going to take a total of six months to get the design done and back into inventory.
    I am certain we should have these by early January.
  • JkaneJkane Posts: 113
    edited 2014-08-04 09:26
    Sadness, January, I really like that board, what was nice was the 40 pin header layout. but I built a pcb board the takes the proto board prop chip and maps it to a 40 pin connector but I was trying not to add any more pcb boards. I was looking to finish this project by end of august. Do you still have stock? or suggestions or inventory that using the layout prior to revision?
    regards
    Jeff
    edited 2014-08-04 09:32
    The 40 pin connector on the Propeller Quickstart is compatible with the 40 pin connector on the Propeller Project USB board, that may work for you.
    http://www.parallax.com/product/40000
    edited 2014-08-06 10:30
    If you really need the project board, the "Project Board Idea Pack" shows as having 13 in stock and includes the Project Board. http://www.parallax.com/product/910-32810
  • PropabilityPropability Posts: 142
    edited 2014-08-06 12:57
    I think I have 4 unused first editions if you want.
  • GenetixGenetix Posts: 1,777
    If Parallax doesn't have an item in stock then you should be able to find it at a reseller.
    I often find who is selling an item by doing an internet search.
    BTW, Radio Shack has QuickStart boards for $8 if you want to try it. Just be aware they are Revision A.
