Regarding Direction calculation using Gyroscope,Magnetometer and Accelerometer
Hello all,
We are using MEMS tri axial sensor which has Accelerometer,Magnetometer and Gyrometer.We have also done Accelerometer and Magnetometer calibration.This sensor is used in borehole application.We have calculated Deviation of borehole using Accelerometer.Now we are stuck up in direction calculation free from rotation(i.e if the sensor rotates also the direction should not change).Is it possible to calculate rotation free Direction using the above three(Acce,Magnet,Gyro) readings. If yes please let me know .
Please find the attached image of Sensor orientation.
S.Naseer
S.Naseer
![TEST SETUP.jpg](https://forums.parallax.com/uploads/attachments/77788/105836.jpg)
What sensors and microcontroller are you using? There are a lot of great sensors and code for detecting orientation. I've been amazed at the results of sensors costing only a few dollars.
