C & SimpleIDE - Why does Code Size jump from 9k bytes to 32kbytes
I've written some simple software to interface to a BlueTooth joystick app on my Samsung tablet.
The program reads the joystick or button value from the app and prints the value on the SimpleIDE terminal.
The first version ran everything in "main". The code size reported by SimpleIDE was about 9k bytes.
The second version ran the bluetooth function in a separate cog and transferred x and y or a button code to main where it was printed on the SimpleIDE terminal. The code size changed to 32k bytes.
The third version commented out the call to the bluetooth function, the declaration of the function, and the cog_run. The code size is 30k.
Each version is listed below. SimpleIDE version is 0.9.45, and I am using the 2014.05.14 Learn Libraries. CMM model
This is the 9k bytes version
This is the multicore 32k bytes version
This is the version with the multicore stuff commented out, 30k bytes
Any ideas?
Tom
/* C code used with Joystick BT Commander App by Kas - used with Samsung Tablet 7-29-14 BT Commander v5 Changed protocol -- code mods to read Joystick and buttons work -- need to do data TX to android
coded button 6 as 'end' to terminate program
Run with terminal
#include "simpletools.h" // Include simple tools
#include "fdserial.h"
fdserial *blut;
char c1[9];
int c0 = 2;
int x;
int y;
int z;
int main()
// fdserial * fdserial_open(int rxpin, int txpin, int mode, int baudrate)
blut = fdserial_open(9, 8, 0, 115200);
while(c0) // continue until button 4 is pressed
int i = 1;
z = 1;
c1[1] = fdserial_rxChar(blut); // read first byte from blut
print("c10 = %d\n", c1[1]);
if(c1[1] == 2) // if STX read next 7 bytes
z = 1;
while(z)
i++;
c1[i] = fdserial_rxChar(blut);
if((c1[i]==3) && (i==3 || i==8)) z=0;
} // end while z android string i = 2 => button, i = 7 => x,y values
if(i==8)
x = (c1[2] -48)*100 + (c1[3]-48)*10 + (c1[4]-48);
y = (c1[5] -48)*100 + (c1[6]-48)*10 + (c1[7]-48);
x = x-200;
y = y-200;
print("x = %d\n", x);
print("y = %d\n\n",y);
} // end if i= 8
if(i==3) print(" button = %d\n\n", c1[2]);
if((i==3) && (c1[2]=='K' || c1[2]=='L'))
c0 = 0;
print(" end \n\n");
} // end if c1=2
} // end while c0
} // end main (temporary)
7-29-14 BT Commander V5 Changed protocol -- mods to read Joystick and buttons work -- need to do data TX to android
Run with terminal
fdserial *blut;
char c1[9];
int c0 = 1;
int a;
int x;
int y;
int okread;
int okwrite;
int x1;
int y1;
int z;
void getbtjoy();
int main()
int x2;
int y2;
okread = 0;
cog_run(&getbtjoy, 20);
while(c0)
if((a==8) && (okread ==1))
okwrite = 0;
pause(50);
x2 = x1;
y2 = y1;
print("x = %d\n", x2);
print("y = %d\n\n",y2);
pause (50);
okwrite = 1;
if(a==3) print(" button = %d\n\n", c1[2]);
} // end while c0
print(" end \n\n");
} // end main
void getbtjoy()
while(c0) // continue until button 6 is pressed
a=0;
int i = 1;
z = 1;
z = 1;
while(z)
i++;
// print("i = %d\n",i);
// print("button = %d\n", c1[i]);
if(i==8)
okread = 0;
a=8;
x = x - 200; // x range -100 to +100
y = y - 200;
while(okwrite =0){ }
x1 = x;
y1= y;
pause(50);
okread = 1;
} // end if i= 8
if(i==3)
a=3;
// print(" button = %d\n\n", c1[2]);
c0 = 0;
//print(" end \n\n");
} // end if c1=2
} // end while c0
} // end getbtjoy
Run with terminal
fdserial *blut;
char c1[9];
int c0 = 1;
int a;
int x;
int y;
int okread;
int okwrite;
int x1;
int y1;
int z;
// void getbtjoy();
int main()
int x2;
int y2;
okread = 0;
// cog_run(&getbtjoy, 20);
while(c0)
okwrite = 0;
pause(50);
x2 = x1;
y2 = y1;
pause (50);
okwrite = 1;
} // end while c0
print(" end \n\n");
} // end main
void getbtjoy()
a=0;
int i = 1;
z = 1;
z = 1;
while(z)
i++;
if(i==8)
okread = 0;
a=8;
y = y - 200;
x1 = x;
y1= y;
pause(50);
okread = 1;
} // end if i= 8
if(i==3)
a=3;
c0 = 0;
} // end if c1=2
} // end while c0
} // end getbtjoy
Any ideas?
Tom
I took the 3rd version and deleted all of the getbtjoy related code and declarations. Still 30k.
Then I deleted all of main and just had int main() { }, still 30 k.
Then I started commenting out each of the includes and declarations - still 30 k until I commented the declaration: int y1; Then the code size dropped to 2 k.
I deleted that statement and retyped it - back to 30 k.
Then I replaced int y1; with int yy; code size = 2k.
I went back to the 2nd code in the above post (multicore, 32 k) and replaced all occurrences of y1 with yy. Code size 9 k. ?!?!?
What is magic about y1? Is it a reserved word?
Totally confused (but the code works)
Tom
How did I know that?
Open the Project Manager and right click on the .c file.
Choose Show Map File ... in the first four items I log, sqrt, etc...
Uncheck "Math Lib" in Project Manager -> Library ....
Everything goes back to normal. BTW, if you don't need floating point use printi() for smaller code.
Thanks for the information. I tried it, and I see how it works. I've had a couple other programs that had very large code size, although the programs weren't that large. I'll have to check them.
Thanks again,
Tom
Tom.
EDIT: I also found that declaring y1 as "int y1 = 0;" resolves the problem.
Thanks for following up Dave.
Thanks for the information. I went back and compiled one of the versions that gave code size 30k, and I found this line (below) in SimpleIDE when I clicked on the build icon at the bottom of the screen. (Since the progam built & loaded to the prop ok, these messages didn't open automatically.)
d:/program files/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/bin/ld.exe: Warning: alignment 2 of symbol `_y1' in d:/program files/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/cmm/short-doubles\libm.a(e_j1.o) is smaller than 4 in C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccgjhUiC.o
There is a warning regarding '_y1', but in my program I was using 'y1'. I would expect that libraries would use names with a leading underscore, but I don't see how that would be confused with a name without one??
As suggested declaring int y1=0 fixes the problem and also removes that warning.
I like using SimpleIDE because I don't have to be bothered by what is happening when my program is built. But I also feel that I am missing a lot by not doing it the hard way. Is there a beginners text or link to using PropGCC that includes the messy stuff (not even sure what it is called - compile, link, and load?)
Thanks again
Tom
