Hello from America! I would like to ask a question. Could you define the parameters in which you need from the
propeller? Do you need the Forth language for the propeller? Do you need the specs of the propeller chip?
Do you need the SPICE information, to simulate the propeller?
Bill Henning, Heater, among others, could help you with your question.
The Propeller Resource Index can provide you with help. This thread will be at the top of the category, in which you
select. (Propeller section) Good Luck!
Your duplicate post has been deleted, since it is against the rules.
We know it's hard for non-English participants to read all the rules, this is just so you know.
Here are the Rules for the Forums:
http://forums.parallax.com/showthread.php/134682-Forum-Guidelines
I am also moving you other post to "General Discussion" because it does not belong in the "Learn" forum.
Best Regards.
