GUIs and Menus
TC
Hello all,
I am STILL working on my reflow oven. I am trying to make the menu more efficient. I have took advise from others here, but because I keep adding things, I am getting lost. I am trying to make a method/object that will handle the GUI, display, encoder, and audio. I thought of following the idea of the WMF framework, but I am getting lost on how to start. I have the encoder (and select) and the audio figured out, But that is as far as I can get.
I just really need some advice, ideas, anything to get my butt in gear and get this reflow oven done.
TC
Encoder code;
Audio code:
TC
Encoder code;
CON
{ ENCODER }
ENCODER_DETE = 1 'ENCODER HAS DETENT
ENCODER_LOW = 0 'ENCODER LOW LIMIT VALUE. OFFERS PADDING FOR ROLLOVER
ENCODER_HIGH = 1000 'ENCODER HIGH LIMIT VALUE. OFFERS PADDING FOR ROLLOVER
ENCODER_PRES = 100 'ENCODER STARTING VALUE. 100 IS CONSIDERED 0. THAT ALLOWS FOR PADDING FOR LESS THAN 0
OBJ
ENCODER : "jm_grayenc2"
VAR
LONG SELECT_FLAG
LONG ENCODER_LAST
LONG ENCODER_VALUE
PRI ENCODER_START
ENCODER.START(ENCODER_A, ENCODER_DETE, ENCODER_LOW, ENCODER_HIGH, ENCODER_PRES)
DIRA[ENCODER_SEL] := 0
PRI ENCODER_READ(AUDIO_FILE_UP, AUDIO_FILE_DOWN)
{ READ ENCODER VALUE, AND PLAY AUDIO }
ENCODER_VALUE := ENCODER.READ ''READ THE ENCODER VALUE
IF ENCODER_LAST == 0 ''IS THIS THE FIRST TIME THE ENCODER WAS READ?
ENCODER_LAST := ENCODER_VALUE ''IF IT IS, SET LAST ENCODER VALUE TO CURRENT VALUE
IF ENCODER_VALUE > ENCODER_LAST ''HAS THE ENCODER GONE UP?
ENCODER_LAST := ENCODER_VALUE ''IF SO, SET LAST ENCODER VALUE
IF AUDIO_FILE_UP <> NULL ''DOES AN AUDIO FILE NEED TO BE PLAYED?
AUDIO_OVERRIDE(TRUE) ''OVERRIDE ANY AUDIO FILE BEING PLAYED
AUDIO_PLAY(AUDIO_FILE_UP) ''LOAD NEW AUDIO FILE
AUDIO_OVERRIDE(FALSE) ''PLAY NEW AUDIO FILE
RETURN TRUE ''RETURN SAYING ENCODER VALUE CHANGED
IF ENCODER_VALUE < ENCODER_LAST ''HAS THE ENCODER GONE DOWN?
IF AUDIO_FILE_DOWN <> NULL ''DOES AN AUDIO FILE NEED TO BE PLAYED?
AUDIO_PLAY(AUDIO_FILE_DOWN) ''LOAD NEW AUDIO FILE
RETURN FALSE ''RETURN SAYING ENCODER VALUE DID NOT CHANGE
PRI ENCODER_SELECT(AUDIO_FILE)
{ ENCODER SELECT CONTROL AND PLAY AUDIO }
IF INA[ENCODER_SEL] == 0 AND SELECT_FLAG <> TRUE ''IS THE BUTTON PUSHED? WAS THE BUTTON PUSH BEFORE?
SELECT_FLAG := TRUE ''FLAG AS BUTTON WAS PUSHED
IF AUDIO_FILE <> NULL ''DOES AN AUDIO FILE NEED TO BE PLAYED?
AUDIO_PLAY(AUDIO_FILE) ''PLAY AUDIO FILE
RETURN TRUE ''RETURN SAYING THE BUTTON IS PUSHED
ELSE
IF INA[ENCODER_SEL] == 1 AND SELECT_FLAG == TRUE ''IS THE BUTTON RELEASED? AND WAS IT PUSHED BEFORE?
SELECT_FLAG := FALSE ''FLAG AS BUTTON AS RELESED
RETURN FALSE ''RETURN SAYING BUTTON WAS NOT PUSHED
Audio code:
CON
{ AUDIO }
'' INTRO = 12 SEC
#0, ACCEPT, ALARM, BACK, CAT, CLICK, CONFIRM, FLIPDOWN, FLIPUP, INTRO, LASER, NO, PWRDOWN, PWRUP, TURRET, YES, NULL
OBJ
AUDIO : "V2-WAV_DACEngine.SPIN"
PRI AUDIO_START
AUDIO.BEGIN(AUDIO_LEFT, AUDIO_RIGHT, SD_MOSI, SD_CLK, SD_MISO, SD_CS, SD_WP, SD_CD)
PRI AUDIO_STOP
AUDIO.END
PRI AUDIO_PLAY(ACTION)
RESULT := \AUDIO.PLAY(@@AUDIO_LIST[ACTION])
PRI AUDIO_OVERRIDE(TRUE_FALSE)
AUDIO.OVERRIDESONG(TRUE_FALSE)
