Right Angle Servo Header?
JonnyMac
My project with Jinyo has inspired the design of a new PCB. I would love to have 3-pin (servo compatible) right-angle headers on the board. Does anyone have a part # I can reference? Did not have any luck searching Mouser or Digikey.
Thanks.
Thanks.
-- http://www.adafruit.com/products/816?gclid=CjwKEAjwxtKeBRDMzoeQmYn5uHcSJACGCF3Dp3FQhW596L3Cft1fBtL3jJS0z7OxpKjY3h5w4PTkBxoCkrTw_wcB
I have gotten the exact samples from http://www.mlelectronics.com/
I need to find the part number, but I believe they where available at http://futurelec.com/
http://www.mlelectronics.com/products/part/index.php?si=TSHR-1
Molex PN:
0022288033 and 0022288032
Digikey PN:
WM50026-03-ND and WM50015-03-ND
If you want a 3x4 setup, Samtec has the TSW10410FTRA that is exactly that. Available at Newark:
http://www.newark.com/samtec/tsw-104-10-f-t-ra/header-2-54mm-tht-r-a-12pos/dp/79P5128
http://octopart.com/partsearch#!?q=TSW10410FTRA
I use these from SparkFun. It looks like the SparkFun headers cost less per pin than the ones from Adafruit.
I generally use a hot knife to cut the plastic. I have not had good luck attempting to break them apart.
Just in time for the big sale, Duane!
DigiKey carries Samtec parts, and I know that Samtec has 3-high R/A headers. Of better yet, if you only need a few, give Samtec a call. They're bend-over-backwards generous with free samples!
They also keep good history of everything you've every ordered, which makes it easy to find again...
TSW-102-08-G-T-RA
is for 2 servos, 3 high (TSW-101-... should be single servo header, 3 high, etc)
I used them with my Ninja board, to make it more menacing (see this photo but imagine all pins pointing radially outwards instead of upwards)
I bet you already know this, but servo connectors are generally a little wider than 0.1". IMO, you don't really want more than four servo connectors right next to each other. Groups of three connectors would be easiest to deal with. The maximum number servo connectors I can group together without resorting to sanding down the plastic is six but the metal pins are bent a bit out of shape by the time they're all connected.
