Am I having a senior moment?
It usually does not happen this early in the day but my brain is obviously fried.
Reference BS Manual page 110
BS2 and 2.5.2 editor are specified with usual point and click
next is:
cnt VAR WORD
one CON 1
main:
cnt = cnt + one
I then hit F7 and '=' is highlighted with message "Expected a binary operator or ')'
Does any one know a good brain surgeon or have an explanation for what is going on here?
If the answer makes me look stupid then so be it and I will quit this endeavor.
next is:
cnt VAR WORD
one CON 1
main:
cnt = cnt + one
BS1 requires Symbol not VAR
I summarized the code because I still have not figured how to cut and past.
After my mid-day nap I went back and found a hanging ',' behind a previous DEBUG command. Continuing through the program I found 3 other hanging commas from my latest revision of the code. I consistently use the F7 as I am writing code but forgot to use it when editing.
Tucking my red face and slinking away.
We have all been there, hang in!
Hey Jim.
Just wanted to point out that 2.5.2 would be the version of the BASIC Stamp Editor Software for Windows while 2.5 is the version of the PBASIC Syntax. When you're clicking the 1.0, 2.0 or 2.5 buttons you're specifying which version of the PBASIC Syntax the editor is to use. 1.0 is only for the BASIC Stamp 1 (BS1) while 2.0 is the default for the BASIC Stamp 2 (BS2). It is purely a coincidence that the current version of the BASIC Stamp Editor Software is 2.5.3(r2).
As a note, you'll want to start most every program by clicking the BS2 and 2.5 icons unless you're using a different model of BASIC Stamp.
Guess who was having a senior moment there?
Chris,
Thanks for the heads-up.
Does this mean that the 2.5.2 editor will pass things that might not run on a plain BS2? Are there no reasons to use it anyway?
Does the editor have no way of knowing what type of BS2 you have it connected to?
Whenever I am more confused than I usually am I double check the handy manual I keep in the same folder as the editor to verify all commands being used are for the basic BS2. So far I have not written code above the Basic Basic Stamp 2. I do seem to have developed a stutter though.
Also, you asked if the editor had any way to know what type of BASIC Stamp is connected. Got to Run / Identify.
