xbee can't be found
hello all.
i have 2 xbees series 2 that I'm trying to use them for communication between to bs2.
i have updated the firmware on the one, through xctu, but the other one it cannot be found.
I'm using a drones adapter and the assuc light is going insane, unlike the other.
the utility can't find it and it seems like there is nothing i can do.
any piece of advice?
thank you in advance!
The one i cannt see is flashing really fast.
The adapter i using http://www.robot-italy.com/en/xbee-usb-board.html
How can i reset to default the setting manually?
As for the Series 1, any set of the same series should be able to connect as they come. There's usually no need to connect them to X-CTU and do anything unless they're really old or were previously reconfigured.
That is an interface board. The XBee module plugs into it.
What are the part numbers for the XBee modules you are using?
Genetix where is the part number? under the xbee?
What is written on your XBee or better yet attach a photo. Also, where did you buy there from because the part number might be listed?
Do any of these look the same?
http://www.parallax.com/catalog/wireless/xbeerf
this is the product im using.
one with the antenna, that i have managed to see through the xctu, and one without an antenna that is the "problematic". i will post an image with the backside when i get home.
the first pair, series2, i cannot find how to fix the problem.
is there any way to reset what is in the xbee manually? by wiring some pins together or something...
Have you look through this book by chance?
http://www.parallax.com/downloads/getting-started-xbee-rf-modules-text
Most of it uses the Series 1 with Parallax interface boards, but the last chapter is on Series 2 and it gives a good explanation of how to use and configure these module.
