Whiteoxe Log of Posts
Ready for posts.....!!!!
Threads on C and SimpleIDE Prop support
http://forums.parallax.com/showthread.php/156566-I-cant-find-enough-on-propeller-C
http://forums.parallax.com/showthread.php/156544-Is-there-an-especially-good-online-site-to-learn-Spin
The L289N motor Controller and Spin code
http://forums.parallax.com/showthread.php/156410-How-To-Use-a-L298N-Dual-H-Bridge-with-a-Microcontroller-(QuickStart-Board)
The useless box http://forums.parallax.com/showthread.php/156593-The-useless-box
How to solder well http://forums.parallax.com/showthread.php/156620-Need-tips-on-soldering?p=1281074#post1281074
THe motor controller chip SN754410NE http://www.scribd.com/doc/21658828/Duel-Motor-Driver-with-Arduino-using-a-SN754410NE-Quad-Half-H-Bridge
Time clock and card, RFID readers http://forums.parallax.com/showthread.php/148558-Employee-time-clock?highlight=carlyn
Which motors to use for best control http://forums.parallax.com/showthread.php/156633-little-yellow-motors-versus-servo-motors?p=1281340#post1281340
QuickStart pins http://forums.parallax.com/showthread.php/156638-This-QuickStart-board-is-behaving-unusually?p=1281339#post1281339
4channel 5volt relay board how to operate http://www.freetronics.com/pages/relay4-4-channel-relay-driver-module-quickstart-guide#.U9puymflpdh
Microcontroller Kickstarts http://learn.parallax.com/KickStart
How transistors work heaters links http://forums.parallax.com/showthread.php/156694-can-the-prop-control-this-4ch-5volt-relay-using-its-3.3-volt-i-o-pins?p=1282314#post1282314
the 4CH Relay and 7404 gate debate http://forums.parallax.com/showthread.php/156694-can-the-prop-control-this-4ch-5volt-relay-using-its-3.3-volt-i-o-pins
Using transistors http://www.electronicsteacher.com/tutorial/learning-to-use-leds-and-transistors.php
write your own language http://forums.parallax.com/showthread.php/156723-Making-your-own-programming-language-I-have-not-the-slightest-clue-so-i-have-only
changing to Linux permanently http://forums.parallax.com/showthread.php/155575-Changing-from-Window-to-Linux-permantly
Kickstarts http://forums.parallax.com/showthread.php/155575-Changing-from-Window-to-Linux-permantly
Esperino java http://www.espruino.com/Quick+Start
Transistors and Spice http://forums.parallax.com/showthread.php/156819-Bnch-of-transistors-trying-to-wire-them-up-now?p=1284799#post1284799
