Expected operator error
Hi there, Im trying to learn spin and can't figure out how to solve this error I keep getting:
The aim of this code Im writing is simply to print 2 values to the serial terminal that are counting at different rates. Here is my code:
obj
pst : "parallax serial terminal"
CON
_clkmode=xtal1+pll16x
_xinfreq=5000000
var
long X
long Y
pub main
pst.Start(115200) 'starting the terminal
Y:=5
X:=0
pst.clear
repeat
pst.dec(X) 'printing value x to terminal
pst.str(String(" " )) 'print a space
pst.dec(Y) 'print value y
pst.Newline 'print new line
Y=Y+5
X++
waitcnt(clkfreq+cnt)
The error I have is with the Y=Y+5 line. I get Error at (24,6) Expected operator. I realise that this is probably a very trivial error but I'm new to spin.
obj
CON
_xinfreq=5000000
var
long X
long Y
pub main
Y:=5
X:=0
pst.clear
repeat
Y=Y+5
X++
Don't forget to indent everything under the "repeat" You probably already did, but the forum software tosses out the spacing if you don't use the Code tags
