Im skipping dsome experiments while learning SimpleIDE No Analogue — Parallax Forums
whiteoxewhiteoxe Posts: 794
edited 2014-07-22 18:00 in Propeller 1
I cant see any amalog pins on the gadgetGangster usb platform. The Learn site here has a prop bord that does have clear adc pins. Am I right or do I need to buy Adc and DAC chips for it ?
    You are correct, the board you are using does not have ADC or DAC. You would need to add the chips to provide these. I saw you bring this topic up in another thread, so those questions can be answered there. You will either need to make your board match the Activity board as far as the I/IO pins being used OR simply adjust the pin numbers used in the Learn examples. Either course of action is acceptable.
