Unpacked Prop Dip Plus Kit
I opened up my prop dip plus kit to bread board it. I thought there would be something to connect it to my usb or serial port inside the packet. Looks like I a wrong. So when you order this from the states you really need to order a prop plug as well or else how do you connect it to your PC ?
Do you have a diagram handy ? thx for your response !
EDIT: The circuit is also in the Prop Datasheet with different values for the resistors and capacitor. The actual transistors used aren't very important as long as you use NPN and PNP transistors as shown in the circuit diagram.
