Simple Serial LCD OBJ question
Of all of the serial objects in the exchange that will drive the Parallax 4-line LCD, which of them will do the minimum job of just writing
to the LCD, and have the minimum code size? Compact. I only need text and integers for this project, but see below for another
question.
Thank you, Daniel
As an aside, how do I print decimal numbers to said LCD? That must require a different object?
I should state that I'm kind of new at his stuff, and have looked into this, but not with much luck.
Thanks for any help.
question.
Thank you, Daniel
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 Tx_pin = 30 Baud = 19_200 PUB Main dira[tx_pin]~~ outa[tx_pin]~~ waitcnt(cnt + clkfreq) tx($0C) ' Clear screen - the datasheet lists all of the command bytes tx("A") ' ASCII "A" tx($0D) ' Carriage return dec(1234) ' Decimal 1234 tx($0D) str(string("This is a string")) PUB Dec(value) | i, x x := value == NEGX 'Check for max negative if value < 0 value := ||(value+x) 'If negative, make positive; adjust for max negative Tx("-") 'and output sign i := 1_000_000_000 'Initialize divisor repeat 10 'Loop for 10 digits if value => i Tx(value / i + "0" + x*(i == 1)) 'If non-zero digit, output digit; adjust for max negative value //= i 'and digit from value result~~ 'flag non-zero found elseif result or i == 1 Tx("0") 'If zero digit (or only digit) output it i /= 10 'Update divisor PUB str(stringptr) repeat strsize(stringptr) tx(byte[stringptr++]) PUB Tx(Tx_byte) | t Tx_byte := (Tx_byte | $100) << 1 t := clkfreq / Baud + cnt repeat 10 waitcnt (t += clkfreq / Baud) outa[tx_pin] := Tx_byte & 1 Tx_byte := Tx_byte >> 1Very no frills, like you asked for. The display doesn't transmit anything, so there's no reason for a receiver in the code, and the max baud according to the datasheet is 19,200, well within the capabilities of Spin. The DEC method is copied from FullDuplexSerial, and gives you your decimal numbers.[SIZE=1][FONT=courier new]PUB DecW(value, width) | sign, idx, box[4] width <#= 15 ' limit width of field to 15 chars if value < 0 ||value ' handle negative (but not NEGX) sign~~ ' will put "-" in the buffer, but not yet else sign~ bytefill(@box, 32, 15) ' fill the buffer with spaces byte[@box+15] := 0 ' zstring repeat idx from 0 to 14 byte[@box+14-idx] := value//10 + "0" ' peel digits from least significant end value/=10 ' ... into buffer if value == 0 ' have run out of digits quit if sign byte[@box+14-idx++] := "-" ' put the "-" in the buffer ' if idx > width ' implement conditional for overflow?? TxStr(result:=@box+15-width) ' print string & leading spaces, return pointer [/FONT][/SIZE]Doesn't this need an object? I've no problem with writing to the LCD, I was looking for a smaller object than the FullDuplxSerial object, if such a thing exists.
Is there an object available that is bare bones, so as not to take up much space?
Daniel
Chris
Now, what about printing floating numbers to the LCD? As in 23.45
Daniel
I do have a method that can accept an integer, a divisor, and the number of decimal places to display the result. For 23.45, that's 2345 divided by 100 displayed to 2 decimal places so you'd call DecF(2345,100,2). Hope this helps.
Chris
PRI DecF(value,divider,places) | i, x { DecF(1234,100,3) displays "12.340" } if value < 0 || value ' If negative, make positive Tx("-") ' and output sign i := 1_000_000_000 ' Initialize divisor x := value / divider repeat 10 ' Loop for 10 digits if x => i Tx(x / i + "0") ' If non-zero digit, output digit x //= i ' and remove digit from value result~~ ' flag non-zero found elseif result or i == 1 Tx("0") ' If zero digit (or only digit) output it i /= 10 ' Update divisor Tx(".") i := 1 repeat places i *= 10 x := value * i / divider x //= i ' limit maximum value i /= 10 repeat places Tx(x / i + "0") x //= i i /= 10Again based heavily of the Dec method from FullDuplexSerial.You are a life saver. Thanks a ton.
I did notice that this doesn't work if my clk is set to 5MHz i.e.
Works fine when running at the 80MHz setting. Is it due to the CON you set as Baud = 19_200 and later used as in the PUB tx(tx_byte) method?
Daniel
Thanks to all for the help. You guys are great!
Daniel
