Odd behavior from my Propeller
I'm noticing some odd behavior from my Propeller, and am wondering if anyone else has seen this sort of thing, or can
tell me what I'm doing wrong here.
In the Main method below, upon startup, the first number printed for "i" is 22, unless I initiate it with i := 0
as shown below commented out. If I set i to zero at the top, then i gets printed as 0, as expected.
I understood that all local variables get set to 0 upon startup. Am I missing something here?
I've included the entire code, just in case my problem is someplace else and I'm not seeing it.
This is what it looks like on the LCD the first time thru:
-168938 delta
0 restarts
22 trials
0 pin 2
And then when I set i to zero, it looks like this:
-161433 delta
0 restarts
0 trials
0 pin 2
In both cases i increases by one each time thru the repeat loop, and is updated to the LCD screen.
And I've reloaded this numerous times. I've even tried loading this into EEPROM.
Daniel
-168938 delta
0 restarts
22 trials
0 pin 2
-161433 delta
0 restarts
0 trials
0 pin 2
Daniel
CON
_clkmode = xtal1
_xinfreq = 5_000_000
RC_Pin = 0 'circuit input pin
LCD_TX = 1 'LCD comm pin
VAR
LONG Value, starts, r1, r2
OBJ
LCD : "FullDuplexSerial.spin"
PUB Initiate
LCD.start(LCD_TX, LCD_TX, 00, 19_200)
waitcnt(clkfreq/100 + cnt)
LCD.tx(12) 'clear screen, Form Feed
waitcnt(clkfreq/100 + cnt) ' must wait 5ms after a Form Feed
LCD.tx(22)
dira[1]~~ 'LCD tx on pin 1
dira[16]~~
Main
PUB Main | i, pinstate
'i := 0 [COLOR=#ff0000] 'IF I DON'T USE THIS, i PRINTS AS 22 INITIALLY[/COLOR]
repeat
Check_Phone
LCD.tx(128) 'line 0, pos 0
LCD.dec(r2 - r1) 'print diff.
LCD.str(string(" delta "))
LCD.tx(148) 'line 1, pos 0
LCD.dec(starts) 'print average
LCD.str(string(" restarts "))
LCD.tx(168) 'line 1, pos 0
LCD.dec(i) [COLOR=#ff0000] 'THIS IS PRINTING AS 22, UNLESS SET TO 0 FIRST[/COLOR]
LCD.str(string(" trials "))
LCD.tx(188)
pinstate := ina[2]
LCD.dec(pinstate)
LCD.str(string(" pin 2 "))
i += 1
PUB Check_Phone | delta 'Phone watchdog; check to see it phone is ON FN
Measure
r1 := Value
outa[16]~~ 'Force leds to light
waitcnt(cnt + clkfreq/2)
Measure
r2 := Value
outa[16]~
ctra := 000 << 26
delta := r2 - r1
if delta <= 0 'if lights are on, return, else start phone
return
Start_Phone
PRI Measure 'Use RC circuit to check phone's status
ctra := 000 << 26 | RC_Pin ' Setup
frqa := 1
outa[RC_Pin]~~ ' Set pin to 3.3V
dira[RC_Pin]~~ ' Set pin as output
waitcnt(cnt + clkfreq / 1000) ' charge the capacitor for 500u
phsa := 0 ' clear counter
dira[RC_Pin]~ ' set pin as input
waitpne(|< RC_Pin,|< RC_Pin, 0) ' wait for to V get to 1.6V
Value := phsa ' store the count in the array
waitcnt(cnt + clkfreq / 10)
PUB Start_Phone 'Cycle phone's power button FN
starts += 1
Thanks, Daniel
