Bike pump suggestion needed for kids to pump 100 psi - Erco? — Parallax Forums
ElectricAyeElectricAye Posts: 4,561
edited 2014-07-14 14:31 in General Discussion
I'm mentoring a robotics team that uses pneumatic components. They have a small air reservoir (a few cubic inches) that can be pumped to 100 psi, but they have trouble using standard bike pumps to get that high, so I'm looking for something that kids can use - purely manual would be okay if kids can actually use it but I'm guessing such a pump would need to be battery powered and/or AC powered. Sought pump would best have a pressure gauge, too. Any suggestions? Erco? Erco, Oh Great Rider of Bikes and Seer of Bargains?
    edited 2014-07-12 09:11
    What kind of bike pumps have you tried? Hand pumps would be awkward for sure, but a good floor pump with a built-in meter should work okay.
    edited 2014-07-12 10:10
    This might work for you, depending on budget of course...
    They don't make em like they used to.
    edited 2014-07-12 10:14
    Sure, what Phipi suggested, or get one of those little 12V auto compressors and run it off a SLA battery. I bought one at Radio Shack long ago on clearance for $10. Slow and gets hot but it works. Depending on the age & strength of your students, that might be better than a floor pump. But get one of those as a backup when your SLA poops out or someone forgot to recharge.
    edited 2014-07-12 10:23
    Get your local Coca-Cola bottler to sponsor you and they can provide a short CO2 tank with regulator that will eliminate the pumping altogether. I used to use one to drive nail guns for finish carpentry (avoids dragging hoses through a nearly completed house) and general automotive stuffy (pneumatic nut driver).
    Anything over about 50PSI can actually pop out an eyeball if pointed at the face. So I has doubts about the safety of 100PSI in any context with kids. Supervision and absolutely no horseplay with pressurized air are important.
    edited 2014-07-12 14:44
    My ground floor bicycle pump claims it can go up to 120 PSI, and the built-in gauge does go that high. However, I tested it up to 70 PSI, and I was concerned that the plastic fittings might no hold much higher than that, so I didn't go any higher. Another issue is that it requires some force even to get to 70 PSI. The barrel of the pump is 1.5 inches in diameter, which works out to a surface area of 1.77 square inches. It takes 1.77*70 = 124 pounds of force to get 70 PSI. 100 PSI would require 177 pounds of force. That's more force than a kid would be able to deliver. Of course, you could use a pump with a narrower barrel, but I don't think you want kids messing around with 100 PSI.
    edited 2014-07-12 14:55
    The piston in my floor pump is 0.9" dia, which works out to 0.64 sq. in. So 64 lb. force for 100 PSI. The gauge on it red-lines at 150 PSI.
    edited 2014-07-12 16:14
    The kids are about 11-13. I've had them try "floor" pumps but they can't handle it. The kids weigh something like 80 lbs. I think.
    Ttailspin wrote: »
    It's an interesting idea. I'll need to check if CO2 is allowed. It's not clear to me how that little gadget regulates or indicates pressure, however.
    ...or get one of those little 12V auto compressors and run it off a SLA battery. ....
    Yes, this is what I had in mind. And I was looking for a specific brand, if possible, preferably based on recent experience.
    I agree. Considering how paranoid schools are about everything, I'm somewhat surprised they let this one slide. But I try to teach the kids how to survive in the real world rather than keep them in the liability bubble, so if the school lets them use 100 psi, I'll teach them that.
    Dave Hein wrote: »
    ... I don't think you want kids messing around with 100 PSI.
    Luckily the reservoir tank is only about 1.5 inches by 4 inches, and the actuator pistons are only about 0.4 inches in diameter, so the forces aren't too bad so long as something doesn't snap loose and fly into their faces. I'm not sure how it compares to rubber band forces, which they are allowed to use, too. Safety glasses are required but I guess I'm still liable for their teeth. (Here you go, kiddies, polycarbonate mouth guards courtesy of PhiPi's laser cutter...)
    Anybody have anything good to say about those pumps you step on? or maybe the type you connect to a drill? I bet a large tank of compressed air wouldn't be allowed in the school buildings - there's probably some rule about the tank size, I'm guessing.
    edited 2014-07-12 17:32
    I believe the kind of pumps you step on (I'm thinking of the bellows kind) are designed for low-pressure things like air beds and beach toys. Is that what you had in mind?
    edited 2014-07-12 18:11
    I was thinking of something that looked like this:
    edited 2014-07-12 19:14
    Oh, yeah. That's more like it, if it'll go up to 100 PSI.
    edited 2014-07-12 19:19
    idbruce wrote: »
    That would work great! I need to find out if such a tank would be allowed in the schools, though. I vaguely recall there might be some kind of tank size limit, or some sort of equivalent kiloJoule storage limit or something weird like that. Heck, if such a tank is allowed, maybe the kids can run it as a fundraiser at events - fill your robot tank for half a buck, etc. Anything would beat watching 80 lb. kids trying to wriggle their entire weight onto a bike pump... or their antique mentor slipping a disk on the thing.
  • 4x5n4x5n Posts: 746
    edited 2014-07-12 19:23
    Be very careful with that 100PSI. Not many hand or foot powered pumps can do it. I would recommend stainless steel tubing and fittings rated for that kind of pressure.
  • idbruceidbruce Posts: 6,197
    edited 2014-07-12 19:31
    There is PVC pipe that can handle much higher pressure than 100 PSI, such as schedule 40 and schedule 80: http://www.engineeringtoolbox.com/pvc-cpvc-pipes-pressures-d_796.html
    stainless steel tubing and fittings?
    edited 2014-07-12 19:40
    idbruce wrote: »
    I've never seen pvc that could safely handle that kind of pressure. I say that out of ignorance though and I'm not surprised that new pvc can take that kind of pressure. With past experience in dealing with hydraulics and other "high pressure" systems it's important that ALL materials be rated for the pressures involved. There's a lot of energy involved at those pressures and safety has to come first.
    edited 2014-07-12 19:46
    I have used and seen PVC used for "low" pressure applications many times. However if a person was worried about using plastic pipe and fittings, brass or plain steel pipe would be sufficient. Stainless steel pipe and fittings would be overkill. Sorry about the correction :)
    edited 2014-07-12 19:59
    4x5n wrote: »
    I've never seen pvc that could safely handle that kind of pressure. I say that out of ignorance though and I'm not surprised that new pvc can take that kind of pressure.....
    It's common for these teams to use flexible Polyurethane Tubing (5/32" OD) for their connections. I've also known some teams that cheat (or, in their own words, allow for leakage) by pressurizing these systems up to 150 psi without any problems. I've not heard of any issues with these components at that pressure. I think the biggest danger is when they use a combo of pneumatic cylinder and rubber bands, a configuration in which the actuators pull back a rubber-banded catapult, for example, then quickly release it.
    edited 2014-07-12 20:01
    Jeepers, here's one (of many) "300 PSI" Chinese compressors for $12. Not making a recommendation per se, but these things are inexpensive. http://www.ebay.com/itm/Portable-12V-Auto-Car-Electric-Air-Compressor-Tire-Infaltor-Pump-300-PSI-New-BR-/151144689537?pt=LH_DefaultDomain_0&hash=item2330ecef81
    edited 2014-07-12 20:13
    I most have lived and worked in a very different world. Were I've seen these types of pressure used it was all SS tubing and fittings. I saw a panel were a line burst under 130psi and it made an amazing mess! To be fair there was a lot of volume of air under pressure. It was enough to scare me the heck out of me.
    edited 2014-07-12 20:25
    If all the tubing and fittings were SS and the pressure was only 130 PSI, either inappropriate fittings were utilized, a faulty fitting or tubing was installed, or someone caused a rupture.
    Consider the lines used on pressure washers, which are normally rubber or plastic. Pressure washers are commonly rated at 2000 PSI or above.
    edited 2014-07-12 20:33
    Of course road bike tires use 100-130 PSI regularly and reliably, no big deal. Smaller diameter presta valves are used.
  • RDL2004RDL2004 Posts: 2,554
    edited 2014-07-12 20:56
    idbruce wrote: »
    I remember an episode of "This Old House", from probably 20 years ago where they went to a factory that made PVC pipe. They showed the QC department testing a piece of pipe that was about 4-6" diameter with many hundreds of pounds of pressure. It swelled to about 3 times maybe 25% more than the original diameter before it finally popped. I was pretty impressed.
    edit: Okay I probably didn't remember perfectly, but just search PVC burst test on YouTube. PVC pipe is pretty tough.
  • LawsonLawson Posts: 870
    edited 2014-07-13 07:26
    To extend this comment. Floor pumps or portable air pumps that are advertized as suitable for road bikes use smaller pistons and pump to 100psi fairly easily. If you do end up getting a portable pump, make sure it has a short hose between the pump and fill fitting. This keeps the fill fitting from leaking while you pump.
    Personally I have a "JoeBlow Sport" floor pump from REI that's easy for me to pump to 85psi. I've also used a $10 12V electric pump that boasted up to 250psi. (I expect that's the pressure that stalls the motor) Both work well.
    Marty
  • abecedarianabecedarian Posts: 312
    edited 2014-07-13 07:42
    Home Depot or Lowes (or similar) should have small-ish air compressors for comparatively low cost, i.e. HD has a Ryobi that can do 150PSI for $20.
    ... or hit the hobby store for a compressor used with airbrushes.
    And I wouldn't suggest PVC or ABS pipe as a storage tank WITHOUT using threaded fittings. But, 'black pipe', the type used for natural gas pipe in the house, it a better / safer option, or even 'RIGID' / IMC type electrical conduit could be used, again with threaded fittings.
    edited 2014-07-14 08:59
    Home Depot or Lowes (or similar) should have small-ish air compressors for comparatively low cost, i.e. HD has a Ryobi that can do 150PSI for $20....
    After pondering this, I think I'll try this or something very much like it.
    Thanks to everyone for your insights and pressure concerns. Much appreciated.
    edited 2014-07-14 11:16
    When I had the furnace hot water system serviced a couple of years ago, the technician deemed the expansion tank defective for the installation. Seems that there is a bladder in in that is factory precharged to 12 PSI, and that failed.
    I told him that I would take care of disposing it.
    Turns out it is rated for 100 PSI. I took the coupling off and took a long drill and pierced the bladder.
    Now it fills my tractor and trailer tires after charging it off my compressor.
    1024 x 768 - 86K
  • W9GFOW9GFO Posts: 4,010
    edited 2014-07-14 14:28
    100 psi sounds high for younger children. For example, in FRC (High School level) pneumatics are limited to 60psi when used to perform any work. The storage tanks can be up to 120psi I think. Also, the pumping must be by a 12v pump, either on the robot or off-board.
    RDL2004 wrote: »
    My friend's son has a scar right near his eye where he was hit by a piece of PVC shrapnel, he was testing a pneumatic launcher for the Scan Eagle UAVs. PVC pipe is pretty tough, right up until it isn't.
