Passing a Long in Prop Assembly — Parallax Forums
ellipserellipser Posts: 43
edited 2014-07-19 14:46 in Propeller 1
I've read the pertinent manual sections repeatedly, and have done a search on the forum, but I still can't get this to work.
The intention of the code is something very simple, to take a variable from Hub RAM, do something to it, and then return it to Hub RAM. In this case, I'm just taking the baby-step of just adding 1 to a variable from Hub RAM, but all I get returned is the ADDR of the variable. I need some way to de-reference the MEM variable.
Any suggestions?
I'm using the PASD debugger, so I can see what it's doing. That part of the code I've deleted because it's just so much noise.
Basically the code should take X0, add one to it, and then put it back in the X0 location in main memory. Instead, it puts the address value of X0 and adds one to it and then puts that into main hub RAM.
It's the whole issue of pointers/dereferencing, just like in C++.
CON
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
VAR
  long x0
OBJ
PUB TestMessages
  repeat
    x0  :=5
     cognew(@entry, @x0) 'Launch assy, pass Shared addr
     Repeat
      waitcnt(clkfreq + cnt)
DAT
              org     0
entry
              mov Mem, PAR 'Retrieve shared memory addr and put it in Mem
              mov ValReg, #0   'Clear value in ValReg
              mov ValReg, Mem       ' Move Mem to ValReg.  This is the mistake, I want the value held in Mem, not the address of Mem
              add ValReg, #1
              wrlong ValReg, Mem 'Move ValReg value to Shared
:endless       jmp #:endless
Mem          res 1
ValReg       res 1
    edited 2014-07-11 08:12
    When you move PAR into Mem, you're storing the address which had been passed to PAR.
    To read the value at the address, "5" in this case, you need to use "rdlong ValReg, Mem"
    Delete your second and third "mov" commands and use the "rdlong" command instead.
    BTW, JonnyMac has several good SpinZone articles on using PASM. The light bulb finally went on for me while working through one of his examples. There's a link to his articles in post #3 of my index (see signature).
  • ellipserellipser Posts: 43
    edited 2014-07-11 08:42
    Beautiful Duane, it worked perfectly. Thank you very much.
    Corrected code for future reference:
    VAR   long x0
    OBJ
    PUB TestMessages
               repeat
                  x0  :=5
                  repeat
    DAT
    org     0
    entry     mov Mem, PAR                         'Retrieve shared memory addr and put it in Mem
              rdlong ValReg, Mem
              add ValReg, #1
    Mem          res 1
    ValReg       res 1
    Maybe it'd be nice to see something a bit more elaborate in the Prop manua under PAR, distinguishing between pointers and contents for this operation. All I saw was this, which leaves out that important line:
    VAR
    long Shared 'Shared variable (Spin & Assy)
    PUB Main | Temp
                     cognew(@Process, @Shared) 'Launch assy, pass Shared addr
                     repeat
                     <do something with Shared vars>
    DAT
                      org 0
    Process     mov Mem, PAR 'Retrieve shared memory addr :loop
                      <do something>
                      jmp #:loop
    Mem res 1
    ValReg res 1
  • JonnyMacJonnyMac Posts: 9,649
    edited 2014-07-11 09:58
    Here's a bit of code that I uses as a template for simple pasm cogs that manipulate values. Note that it allows you to send a (non-zero) command value that dictates the manipulation
    I tag this onto a spin program for development, then trim and move to its own file if what I do is useful as a stand-alone object.
    var
      long  cog
      long  cmd
      long  value
    pri start
      stop                                                          ' stop if running
      cog := cognew(@entry, @cmd) + 1                               ' lauch the cog
      return cog                                                    ' return load status
    pri stop
      if (cog)                                                      ' if running
        cogstop(cog - 1)                                            '  stop
        cog := 0                                                    '  mark stopped
      longfill(@cmd, 0, 2)
    pri run_command(c, v, wait)
      repeat while (cmd)                                           ' let previous command finish
      value := v                                                    ' setup value (do this first!)
      cmd   := c                                                    ' enable pasm cog
      if (wait)
        repeat while (cmd)
      return value
    dat { pasm code }
                            org     0
    entry                   mov     r1, #0
                            wrlong  r1, par                         ' clear cmd
    get_cmd                 rdlong  r1, par                 wz      ' look for command
            if_z            jmp     #get_cmd                        ' if 0, try again
                            mov     r2, par                         ' r2 = hub address of cmd
                            add     r2, #4                          ' r2 = hub address of value
                            rdlong  r2, r2                          ' r2 = value
                            cmp     r1, #1                  wz      ' cmd == 1?
            if_e            jmp     #cmd1
                            cmp     r1, #2                  wz
            if_e            jmp     #cmd2
                            cmp     r1, #3                  wz
            if_e            jmp     #cmd3
    bad_cmd                 jmp     #entry
    cmd1                    ' do something with value in r2
                            shl     r2, #1                          ' multiply by 2
                            jmp     #cmd_exit
    cmd2                    ' do something with value in r2
                            sar     r2, #1                          ' signed divide by 2
                            jmp     #cmd_exit
    cmd3                    ' do something with value in r2
                            adds    r2, #3                          ' add 3
                            jmp     #cmd_exit
    cmd_exit                mov     r1, par                         ' point to cmd
                            add     r1, #4                          ' advance pointer to value
                            wrlong  r2, r1                          ' write r2 to value
                            jmp     #entry
    r1                      res     1
    r2                      res     1
                            fit     496
    edited 2014-07-11 14:56
    Thanks Johnny Mac.
    I'm going to try that out.
    Link: http://classic.parallax.com/downloads/propeller-spin-zone-articles-and-code
    BTW, it seems that the PASM takes a #4 jump in memory to just go one more memory location, huh? Intuition would tell me it would be just as simple as adding 1, but apparently you have to add 4 to move one.
  • HarpritHarprit Posts: 539
    edited 2014-07-13 06:17
    Each long takes up 4 bytes
    H
    edited 2014-07-13 07:59
    PASM sees the hub as an array of bytes, so moving from one long to the next requires the addition of 4.
    Note that PASM sees the cog as an array of longs, so you would use 1 when advancing an address within the cog. Here's an example from an LED driver I wrote.
    dat { single-shot ws2812 driver }
                            org     0
    ws2812ss                rdlong  r1, par                         ' hub address of parameters -> r1
                            movd    :read, #resettix                ' location of cog parameters -> :read(dest)
                            mov     r2, #6                          ' get 6 parameters
    :read                   rdlong  0-0, r1                         ' copy parameter from hub to cog
                            add     r1, #4                          ' next hub element
                            add     :read, INC_DEST                 ' next cog element
                            djnz    r2, #:read                      ' done?
    The value in INC_DEST is 1 shifted left by nine bits to put it into the destination field of the instruction (INC_DEST is for increment destination).
    edited 2014-07-18 12:12
    You mean I can have the hub look into the cog ram? Maybe that's what I need to do, and use a bit to do the job of a traffic cop, like a semaphore or flag.
    What I'm looking for is a trick to basically get the timing right. I'm having the assembly program do the Bresenham algorithm and then send the results to the hub, but only at the right time, after each calculation. The problem is that the timing isn't right. I want to do it sort of like a DataReady bit in a serial protocol, where the cog tells the the hub another piece of data is ready, and to output the data to Parallax Serial Terminal. The Brensenham is lightning fast, so I wanted to the cog to say, "Data is ready" and the hub to say "I'm done outputting the data, it's OK to proceed with another calculation." In this sample, I eliminated all the irrelevant stuff. Instead of a Bresenham, I'm just adding 5 to a counter and uploading it to the hub.
    I'd like to use assembly in the Hub, but I know that's not permitted.
    CON
    VAR
      long Cog, TestVar
      long x0
      long TxControl
      long x_value_from_cog
    OBJ
     pst: "Parallax Serial Terminal"
    ' dbg   :       "PASDebug"                '<---- Add for Debugger
    PUB TestMessages
      ''Send test messages to Parallax Serial Terminal.
    pst.Start(57_600)
    x0  :=5
    TxControl:=0    'When TxControl is 0, sending data to PST is disabled
        repeat                        'Blocking function, waiting for TxControl to
           if TxControl==0            'equal 1.  When it is 1, do the output to
              next                    'the terminal
           Pst.NewLine
           pst.Str(String(pst#NL, "Inside SpinLoop"))
           pst.Dec(x_value_from_cog)
           TxControl :=0       'Tell the cog it's done with output to PST, and proceed
    DAT
                  org     0
    entry
                  mov X0Pntr, PAR        'Retrieve shared memory addr and put it in X0Pntr
                  rdlong X0cog, X0Pntr   'Retrieve X0
    loop          add X0cog, #10          'just something simple like adding 10 to a number
                  cmp X0cog, #120 wc   'the real code would have the Bresenham here.
         if_nc    jmp done
                  mov X0Pntr, PAR           'Get to memory location of x_value_tx
                  add X0Pntr, #8
                  mov Output_X, X0cog       'and move Output_X into it
                  wrlong  Output_X , X0Pntr
    Update_Data_Flag
                   mov X0Pntr, PAR           'Get to memory location of TxControl
                   add X0Pntr, #4            'and set it to 1, so that Spin section knows
                   mov temp, #1              'that data is ready
                   wrlong temp, X0Pntr
    Wait_Until_Main_Done
                   rdlong temp, X0Pntr
                                            'delay so that MainCog has time to send data to PST
                  rdlong Delay, #0           'Get clock frequency
                  shr Delay, #2              'Divide by 4
                  mov Time, cnt              'Get current time
                  add Time, Delay            'Adjust by 1/4 second
                  waitcnt Time, Delay        'Wait for 1/4 second
                  cmp temp, #1  wz
        if_nz     jmp Wait_Until_Main_Done
                   jmp  loop
    done           jmp done
    X0Pntr         res 1      'X0Pntr points to MainCogRam memory
    X0cog          res 1
    temp           res 1
    Delay          res 1
    Time           res 1
    Output_X        res 1
  • AribaAriba Posts: 2,695
    edited 2014-07-18 13:04
    All your jumps in PASM miss the # before the label. As you have it now it is a indirect jump. To jump to a label you need to write:
    label
               jmp #label
    Then there is something wrong with the wait for the Flag from Spin: You set the TxControl to 1 in PASM and wait then until it is 1. So you don't wait - you need to wait until Spin sets it to zero. Then you don't need the 250ms delay anymore.
    Andy
    edited 2014-07-18 15:01
    Ariba wrote: »
    label
               jmp #label
    Andy
    OK, I'll try that tonight. I had a weird error where the compiler said basically that the label doesn't exist, but it did. I took out the : or the # (can't remember) and then it compiled OK.
    I was trying various options with the delay, etc. Assembly is very, very fast, so I put that delay in. Thanks, btw.
    edited 2014-07-19 11:26
    Thanks, I made the modifications to the code, and it does what I want at this point. I've included the code below just in case someone searches the forum at later date in need of functionality.
      ' Send test messages to Parallax Serial Terminal.
      ' to show how a cog can get data from the MAIN hub,
      ' do something to it using lightning-fast assembly,
      ' and then send it back up to the MAIN hub to be used as needed.
    CON
    VAR
      long Cog, TestVar       'Don't change the order of the variables.  Pointers in use!
      long x0
      long TxControl
    OBJ
    PUB TestMessages
    pst.Start(57_600)
    x0  :=5
              next                    'the terminal
           Pst.NewLine
           TxControl :=0            'set it back equal to 0 to tell the cog assembly OK to cont.'
    DAT
                  org     0
    entry
                  rdlong X0cog, X0Pntr   'Retrieve X0 using the pointer
    loop          add X0cog, #10          'Do something pretty useless, just to do something in
                  cmp X0cog, #120 wc      'CogRAM
           if_nc  jmp #done
                  add X0Pntr, #8
    Update_Data_Flag
                   wrlong temp, X0Pntr
                   rdlong temp, X0Pntr
                   cmp temp, #1  wz
        if_z       jmp #Wait_Until_Main_Done
                   jmp  #loop
    done           jmp  #done
    X0cog          res 1
    temp           res 1
    Output_X        res 1
    BTW, what does "0-0" do in Johnny Mac's code? I'm not sure if that's a number, or a calculation, or maybe just trying to say, "put your variable here".
    ellipser wrote: »
    Thanks, ...........
    The 0-0 indicates that the data there is modified by some other code in the program.
