Help with using the result value returned from a method
Hi there,
I'm trying to figure out how to use the result in the calling method that is returned from the called method--hope that's clear.
This should help. This is an example only, but is representative of my code--can't get to it right now.
How do I check the result returned from the Start_Something method in the Main method?
I was able to find out how to set the result to be returned in the manual, but not how to use it once returned.
Thank you, Daniel
PUB Main Start_Something <do some other things> PUB Start_Something : Fail <check some pins> if SomePin == 0 <things are good here> else Fail := 1
Thank you, Daniel
if start_something ' responseor you can assign the result to some other variable and use it later:Yes, <do some other things> will be executed, along with many other lines following that statement.
I'm looking for a way to determine in the Main method whether or not there was success in the
Start_Something method. I suppose that I could have used a global variable, but why not use
the return value, since it's there.
And just for clarification, would this also work?
Daniel
