Servos Propeller GCC - Need to Drive 8 servos
I have been looking for a propeller C routine that will drive 8 servos in background. The "servo.h" library functions only support 7 servos, if memory serves.
1) Has there been an update to the C Libraries of late that support 8 or more servos?
2) Is there an assembly routine that I can call from a propeller C program that runs in background that will drive 8 servos?
I have searched the forums, but came up dry (probably due to my inadequacies of using advanced search engine).
BTL24 (Brian)
BTL24 (Brian)
I'll be happy to help you write a C interface and wrappers for it if you post a first attempt.
Forum search is to blame for inadequacies. Just use google. " site:forums.parallax.com servo "
I assume this will run in parallel with my current executive code that will store off the 8 servo commands to this routine. I will be reading continuously from an SD card with standard file I/O. I assume this servo code wont interfere with those operations.
I am currently using servo_angle function from servo.h libraries and all is well. Just don't want to mess something up.
Thanks again...
Brian (BTL24)
Start with making a C version of servo32. Then add API candy wrappers that have similar names to servo.h functions.
The hardest part of making a C -> PASM interface is by making a mailbox structure for communications.
The mailbox in spin appears to be this:
long ZoneClocks long ServoPinDirection long ServoData[32] '0-31 Current Servo Value long ServoTarget[32] '0-31 Desired Servo Value long ServoDelay[32] '0-31 Servo Ramp DelayYou can include these files in the SimpleIDE project directly to use the PASM.
Servo32v9.spin
Servo32_Ramp_v2.spin
The PASM code symbols for each of those will be:
extern int binary_Servo32v9_dat_start[];
extern int binary_Servo32_Ramp_v2_dat_start[];
I suggest looking at the SimpleIDE/Learn/Simple Libraries/TextDevices/libfdserial project for an example to get started.
If that turns out to be "just too hard" try the spinwrap program. http://forums.parallax.com/showthread.php/153919-SpinWrap-a-tool-for-allowing-C-or-C-to-use-Spin-Objects?p=1243144&viewfull=1#post1243144
Having just updated my "learn" folders tonight in getting to review the SimpleIDE/Learn/Simple Libraries/TextDevices/libfdserial project , I happened to notice that the latest version of the C library "servo.h" now handles 14 servos or more!
This solves my problem immediately. I will be testing over the next several days and report status.
Jazzed... I will put the spin code on hold until I check this out. I will be getting back to it as it is a great example on how to include Spin programs in C.
Brian (BTL24)
Well Surprise... Surprise! When I compiled my old program with new libraries, it ran out of Hub memory (Over by 4,824 bytes).... OUCH! LOL.
But, I converted some functions like scanf to getStr and saved a bundle of memory. Whew! Still need to try out that 8th servo...but this little issue got in the way.
Will keep you posted...
Brian (BTL24)
The 8th servo works like a champ! Very pleased my friends... very pleased.
I even may expand my project more and take advantage of the 14 servos. Nice to have margin.
Brian (BTL24)
Thanks... I will take a look.
Brian
