nested loops in c-Propeller
Can anyone help me with a nested while loop that blocks mij propeller chip?
Test_Een_Stappenmotor
Herhalingen via while loop
Version 0.94 for use with SimpleIDE 9.40 and its Simple Libraries
#include "simpletools.h" // Include simpletools
int I=20;
int m=0;
int r;
int main() // de main functie
while(1)
print("r = %d\n", r);
high(1);
while(m<2) //Aantal herhalingen
high(2);
for(int n = 1; n <= I; n++) // Count to ten
high(0); // Zet de pulsuitgang op 0
pause(300);
low(0); // Zet de pulsuitgang op 1
pause(300); // 0.5 s between reps
print("Stap = %d\n", n);
low(2);
low(1);
high(0);
print("aantal = %d\n", m+1);
pause(500);
m++;
int I=20;
int m=0;
int r;
while(1)
high(1);
high(2);
pause(300);
low(2);
low(1);
high(0);
pause(500);
m++;
Thanks very mutch for your prompt reply.
I understand now what happened, but is there a better way to have nested "while's"?
regards
Greg
I will say something about your for loop:
When just using for loops for counting iterations it is common practice to count from zero and check for less than the maximum count. It's a bit less confusing for readers that way. Unless there really is a reason for wanting to start at 1 or some other value.
Also if any values in your code are actually constants it is better to define them with "#define" rather than using a variable, again that makes life easier for the reader as he now knows these are supposed to be fixed values that will not change at run time.
In general people like to see longer meaningful names for variables rather than just single character "m", "n". That makes the code easier for readers to understand and helps you when you are searching for names in an editor.
