Daisy Chain Propellers?
Is It possible to connect two Propellers together. so instead of 8 cogs you could have 14 (subtract one cog per chip to connect)? I'm not asking for any reason other than to see if I can be done. Why stop at two...can you connect three or four?
PropForth even provides a system for controlling and communicating with individual cogs under such a scheme.
The Propeller 2 will have significantly more Hubram, 16 cogs, and several new features ... including ADC and DAC i/o. In many cases, that will make doubling up on Propeller no longer necessary. I guess it won't have all the ROM features of a video font, binary log table, and binary sine table. It will run faster as well.
How could you have missed this thread http://forums.parallax.com/showthread.php/156350-PropBus-Single-wire-multi-propeller-comm-link which has been discussing this topic for some days now?
However, in the simple cases you need to program each Propeller independently with their own separate programs. What would be cool is to be able to write a single program that contains parts for multiple connected Propellers and be able to load that program into the "network" in one go via a single programming connection.
I believe people have created software that allows a "master" Propeller to reset a "slave" Propeller and download code to it. I have no idea if anyone worked that sort of thing into an integrated system.
http://forums.parallax.com/showthread.php/124343-Parallax-Propeller-Programs-Propellers-in-ParallelV1.0-Tribute-to-the-BigBoy-4?highlight=bigboy
This works really well.
