Know of any "top looking" modulated IR receivers?
Hello all,
I am using infrared beams in many of my projects lately. Sometimes I really like side-looking IR receiver, but there are times that a top-looking receiver might be nice. I have seen top-looking or 5 mm LED casing photoresistors and phototransistors, but the only modulated IR receivers I seen are side-looking. Has anyone see a top-looking modulated IR receiver? Our laboratory recently got a 3D printer, and although I can incorporate a nice square slot into many of my projects to accommodate the the modulated IR receivers, it would be much easier to drill (or print) a 5 mm hole like I can for the IR LEDs. Am I out of luck?
Otherwise, get a side-looker (a dime a dozen) and fold them over.
A round LED casing is going to be very hard to find, but you can get SMD models that are designed for both side/top mounting, and there are also ones with single domes, which could sit behind a round hole.
All the volume is in SMD, these days, so best to use that if you want reliable supply.
Edit: They are also on Amazon, where I found this pinout description: Starting from the flat side: signal out, ground, V+.
http://www.ebay.com/itm/321213163461
http://www.amazon.com/Reception-Distance-Infrared-Receiver-2-7V-5-5V/dp/B008OTO0GO/ref=sr_1_1?ie=UTF8&qid=1404793564&sr=8-1&keywords=PIC-0038N
That looks great! I don't want to invest too much in a "hard to find" part, but 20 will last me for a good while. I got the bunch from Amazon, forgot to hit check out last night...
My lab mate might have bought the ones from ebay. Either way, we are set for a while.
Wass:
That actually is a neat mount, but yeah it is still a bit bulky. After you mentioned that part I found some other mounts like it. I don't know if I could bring myself to buy something at radio shack, aside from last minute resistors and wire.
Also, you are totally right, the TSOP38240 should work great. I didn't notice on the data sheet that it mentions both horizontal and vertical detection. I am going to get some of these two. That form factor seems pretty common. Also, pretty cool that Vishay offers receivers for different frequencies. I wonder if I could do something fun with that.
jmg:
You are right, SMD is a good option. I'm trying to avoid it for now because I don't want to invest in another skill/tool set for SMD and printing circuit boards, and I don't want my colleagues to need that skill/tool set either. I do a little bit of SMD work, it isn't that bad. But I think I would prefer through-hole when ever possible.
Thanks a bunch guys, this has really helped me out.
http://www.goldmine-elec-products.com/prodinfo.asp?number=G8155B
Radio Shack is $0.49 cheaper and available on hang tags.
Early (10+ years ago) Sony tin-cube models were continuous signal compatible, but these probably are not.
http://forums.parallax.com/archive/index.php/t-141772.html
http://www.ebay.com/itm/10pcs-15-18M-Reception-Distance-5V-Infrared-Receiver-Modules-PIC-0038N-/311039852990?pt=LH_DefaultDomain_0&hash=item486b6b81be
I succumbed...order placed.
KSM-2012 IR Receiver Module 36.7 kHz KSM-2012TE2S
at TAYDA Electronics http://www.taydaelectronics.com/sensors-transducer.html
41 cents and very cheap shipping. I just got a few and an assortment of other stuff.
Aaron
