HB-25 Motor Controller with standard R/C receiver
I am considering to buy the HB-25 Motor Controller. I would like to control the motor controller by an R/C controller. But I don't need any encoding etc. Is it possible to just connect the motor controller to a R/C receiver and control it?
Thanks in advance for your help,
jolau
jolau
http://www.parallax.com/sites/default/files/downloads/HB-25-Motor-Controller-Guide-v1.3.pdf
I use two older HB-25 motor controllers.
I'm driving two automotive windshield wiper motors on a robotic platform I'm building.
The tricky bit about the HB-25 controllers is in the initialization of the controllers.
I'm using a BS1 microcontrollers to turn on a relay that powers up the HB25's and initializes them.
While I'm not using an RC transmitter/receiver, I believe it would work.
Check the documentation again concerning initialization, I'm thinking you will need to add an initialization circuit
before you can use your RC controller.
I hope this helps you in some manner.
http://www.intersil.com/content/dam/Intersil/documents/icm7/icm7555-56.pdf
I believe the 2 in one package is the 7556. But one alone just might do the trick.
http://www.edaboard.com/thread204896.html
