ADC Hex converision questions...... — Parallax Forums
sir_hacksalotsir_hacksalot Posts: 15
edited 2014-07-05 03:12 in BASIC Stamp
Hello!
Im havin fun which is the important part!
Anyway.
The ADC0831 code is the heart of my current hack. I have modified it and added buzzers lights relays warnings and an LCD. It pretty cool. Of course I want to apply my new found Voltage monitor to a 12vdc system. I knew Id have to tackle the conversion issue since I will be using 5Vref. So off I went with my 8th grade math skillz, parallax basic stamp forum and google.
The stock code can be found on pages 156 -157 in Stamp works. Please note the $139c value for Cnts2Mv. The comment says that 5000 / 255 = 19.6. Awesome. I don't know Hex from a hole in the wall so I figured all of this was true. Using this information I came up with $1388 for the hex value. Curious, I plugged it in and now my display reads 4980. Hmmmm. Off to study Hex for a few hours......... I stumbled upon some awesome code while perusing the forums from Tracy Allen and hacked it up to help me solve the problem. Here it is...
'{$STAMP BS2sx}
'{$PBASIC 2.5}
' ----------[ revision history ]------------------------------------------------
' Tracy Allen, [URL="http://www.emesystems.com"]www.emesystems.com[/URL]   when?
' Randy Cookson Hacked it up on July 2, 2014
'  This awsome Tracy Allen code was hacked up and reconfigured to find the HEX
'  value for the conversion of the 255 bit result from the ADC0831 reading 5Vref to show the 12vdc scale on the debug
'  and LCD.  I got close.  I have no Idea why the 0831 code used 5020 or #139c to
'  get the terminal to show 5000 which is actully = $1388  Where did the 20 Hex points come from?
idx VAR Byte
precision VAR Word
Hexcnt              VAR      Word
hexnum              VAR      Word
MultV               VAR      Word
bitV                VAR      Word
targetV             VAR      Word
targetHEX           VAR      Word
result              VAR      Word
com                 VAR      Byte
main:
DEBUG CLS
DEBUG "First enter number of decimal places desired: "
DEBUGIN DEC precision
DEBUG CR
DEBUG CLS, "Enter highest bit division # ie. 8 bit would be 255 "
 DEBUGIN SNUM bitV                  ' retrieve number in any format
 DEBUG CLS, CRSRXY, 6,0, "Decimal bit value:...      ", DEC bitv
DEBUG CRSRXY, 0,2, "Enter desired display result. ie. 5000 "
 DEBUGIN SDEC targetV
  DEBUG CRSRXY,0,2,CLREOL
  DEBUG CRSRXY, 6,1, "Target Value entered is:.. ", DEC targetV ,CR
MultV = targetV + 20   '<<<<<<<<   CRITICAL WTF CODE HERE
  DEBUG CRSRXY, 6,2,DEC targetV," / ",DEC bitV," = ", DEC targetV/bitV,"."
  ' main digit kicker outer...
  FOR idx=1 TO precision-1
    targetV=targetV//bitV*10
    DEBUG DEC1 targetV/bitV
  NEXT
  DEBUG DEC1 (targetV//bitV*10+5/bitV),CR,CR  ' round off final digit
  DEBUG CRSRXY, 0,8, HEX MultV
After hours with various beans and pieces of paper I discovered that If I add 20 to my targetV variable (now MultV) I get the desired output for finding the HEX value.
I have figured out what the Hex conversion for 12v is. I think its $2f10. Why is the question. Why do I have to add 20 to the HEX value to get my targeted number.
Here is the Actual code Im using. Its original skeleton is the code from the book.
' {$STAMP BS2sx}
' {$PBASIC 2.5}
' -----[ Program Description ]---------------------------------------------
'Battery monitory with LCD display.
'--------[0831 pinout to stamp---------------------------------------------
' 0831 pin 1      CS        MCU 0
' 0831 pin 2      Vin+       wiper 10k pot with 220 Resistor (pot = VDD / VSS)
' 0831 pin 3      Vin-       VSS (GND)
' 0831 pin 4      GND        VSS (GND)
' 0831 PIN 5      Vref       VDD +5VDC (this will be from Vref chip)
' 0831 pin 6      DO        MCU 2
' 0831 PIN 7      CLK       MCU 1
' 0831 PIN 8      VCC        VCC +5VDC
' -----[ I/O Definitions ]-------------------------------------------------
CS              PIN     0                       ' chip select (ADC0831.1)
Clock           PIN     1                       ' clock (ADC0831.7)
DataIn          PIN     2                       ' data (ADC0831.6)
' -----[ Constants ]-------------------------------------------------------
BAUD            CON    $406e                    'Set Baud rate to 19200 inverted  BS2 = $4020  BS2sx = $406e
CLR             CON    012                       'LCD Clear Screen instruction
LINE1           CON    001                       'Cursor Home Position
TX              CON    9
Spkr            PIN    4
freq            CON    1500
freqtime        CON    200
BatFull         CON     12000
BatRecover      CON     11900
BatLow          CON     11800
BatCrit         CON     11700
BatDead         CON     11500
Bat_Good_led    CON    10
Alarm1          CON    12
Alarm2          CON    11
SysPower        CON    5
Sdelay          CON    10
Cnts2Mv         CON    $2f10 ' x 19.6  ((Actually this  hex is 5020 dec)
'                             (TO millivolts)    $139c is the original value.
' -----[ Variables ]-------------------------------------------------------
LCDVolts        VAR     Word
result          VAR     Byte                  ' result of conversion
mVolts          VAR     Word                    ' millivolts
 ' -----[LCD initialize]----------------------------------------------------
Initialize:
PAUSE 2000
Recover:
LOW Alarm1
LOW Alarm2
FREQOUT Spkr, freqtime, freq
HIGH tx
PAUSE 200
SEROUT TX,BAUD,[003]                 'RESTORE DISPLAY
SEROUT TX,BAUD,[015,040]             'Set Contrast
SEROUT TX,BAUD,[020]                 'Turn Scroll Off
SEROUT TX,BAUD,[024]                 'Turn Wrap Off
SEROUT TX,BAUD,[004]                 'Turn Cursor Off
SEROUT TX,BAUD,[CLR]                 'Clear Screen
SEROUT TX,BAUD,[LINE1]               'Goto Home Position
SEROUT TX,BAUD,["  Power Monitor"]   'Display Text
SEROUT TX,BAUD,[017,000,001]         'Position Cursor at Col 1 of Line 2 on LCD
SEROUT TX,BAUD,["     Running"]      'Display Text
PAUSE 1000                           'Pause
' -----[ Initialization ]--------------------------------------------------
Reset:
  DEBUG CLS,                                    ' create report screen
        "ADC....  ", CR,
        "volts... "
' -----[ Program Code ]----------------------------------------------------
Main:
HIGH Bat_Good_led
LOW Alarm1
LOW Alarm2
HIGH SysPower                                 ' connecy or disconnect all loads
  DO
    GOSUB Read_0831                             ' read the ADC
    mVolts = result */ Cnts2Mv                  ' convert to millivolts
      DEBUG HOME,                                 ' report
          CRSRXY, 9, 0, DEC result, CLREOL,
          CRSRXY, 9, 1, DEC mVolts
SEROUT TX,BAUD,["Millivolts ",DEC5 mVolts]
SEROUT TX,BAUD,["Sys. Oporational"]
IF mVolts < BatLow THEN
GOTO Low_Battery:
ELSEIF mVolts < BatCrit THEN
GOTO Bat_Critical:
ELSEIF mVolts < BatDead THEN
GOTO Emergency_stop:
ENDIF
  LOOP
'-------------------------- [Sub routine]-------------------------------------------
Read_0831:
  LOW CS                                        ' enable ADC
  SHIFTIN DataIn, Clock, MSBPOST, [result\9]    ' read ADC
  HIGH CS                                       ' disable ADC
  RETURN
'-------------------------- [Sub routine]--------------------------------------------
Low_Battery:
LOW Bat_Good_led
  DO
   PWM Alarm1,255,100
          CRSRXY, 9, 1, DEC mVolts DIG 3,
                       ".", DEC3 mVolts
SEROUT TX,BAUD, ["Millivolts ", DEC5 mVolts]
SEROUT TX,BAUD, ["  Low Battery   "]
GOTO Bat_Critical:
ELSEIF mVolts > BatRecover THEN
GOTO Main:
ENDIF
  LOOP
Bat_Critical:
   DO
  PWM Alarm2,200,200
  PWM Alarm1,255,200
                       ".", DEC3 mVolts
SEROUT TX, BAUD, ["Millivolts ", DEC5 mVolts]
SEROUT TX, BAUD, ["Battery Critical"]
IF mVolts > BatLow THEN
GOTO Low_Battery:
ENDIF
  LOOP
Emergency_stop:
SEROUT TX,BAUD,[003]                 'Hide display
SEROUT TX,BAUD,["   Battery at "]  'Display Text
SEROUT TX,BAUD,["  unsafe level"]       'Display Text
PAUSE 1000                           'Pause
PAUSE 1000
SEROUT TX, BAUD, ["  Shutting down"]
PAUSE 1000
FREQOUT Spkr,1500,1500
LOW SysPower
 DO
HIGH Alarm2
                       ".", DEC3 mVolts
SEROUT TX,BAUD,["  Standby mode..."]
 LOW Alarm2
PAUSE 3000                            'charge stand by      MODIFY FOR LONGER DELAY BASED ON CSD.
PAUSE 2500
SEROUT TX,BAUD,[" 12 Vdc detected!"]
PAUSE 2500
LOW Alarm2
GOTO Recover:
ENDIF
LOOP
My code works so far but why? lolz. you guys are great!
  • GenetixGenetix Posts: 1,777
    edited 2014-07-03 19:39
    To answer your question regarding the constants:
    Page 158 of StampWorks it says:
    Dividing five (volts) by 255, we find that each bit in the result is equal to 19.6 millivolts.
    For display purposes, the result is converted to millivolts by multiplying by 19.6 (result */ $139C).
    On page 160, its also says:
    With a Vref of 2.55 volts, the voltage per bit is 0.01 volts, nearly twice as when 5.00 volts was used, for Vref, and the conversion to millivolts is simplified.
    Before running the program modify the Cnts2Mv constant to reflect the Vref change.
    With each bit equal to 0.01 volts (1/100) we can multiply by 10 to covert to millivolts (1/1000).
    Cnts2Mv CON $0A00 ' x 10 (to millivolts)
    Refer to Page 85 of What's a Microcontroller? V3.0 for an explanation of the */ operator.
    Step 2 says take the fractional value that you want to use and multiply it by 256.
    Here's the math:
    Reference Voltage / # of bits for the ADC = Volts per bit
    The ADC0831 is 8-bit so it outputs a value from 0 to 255 (2^8 = 256).
    Vref = 5V
    5V / 255 = 0.019607843 which rounds up to 0.01961 volts per bit or 19.61 mV per bit.
    19.61 x 256 = 5020.16 which rounds up to 5020 which is $139C, for mV per bit.
    Vref = 2.55V
    2.55V / 255 = 0.01 V / Bit = 10 mV per bit
    10 x 256 = 2560 = $0A00, for mV per bit
    Hexadecimal is Base-16 so the digits range from 0 to F.
    0-9, A = 10, B = 11, C = 12, D = 13, E = 14, F = 15
    $139C = 1(16^3) + 3(16^2) + 9(16^1) + C=12(16^0) = 1(4096) + 3(256) + 9(16) + 12(1) = 4096 + 768 + 144 +12 = 5020
    Remember from algebra, that anything raised to the 0 power is 1 (by definition).
    $0A000 = 0(16^3) + A=10(16^2) + 0(16^1) + 0(16^0=1) = 0 +10(256) + 0 + 0 = 2560
    The Windows calculator has a built in converter so click View - Programmer. Click View - Standard to return to the regular calculator mode.
    Some scientific calculators also have Hex - Dec and vice-versa conversion.
    I noticed that your program using GOTOs within a DO-LOOP which is very bad practice. Instead you should use what's called a State Machine.
    The State changes with conditions and code is executed or skipped depending on the current State.
    Anything connected to an I/O pin should be a PIN and not a CON variable.
    You have a lot of LCD code so put as much of it as you can in a subroutine or a set of subroutines.
    Do you have a schematic of your circuit?
    edited 2014-07-03 20:01
    It's important to note that hexadecimal, decimal, binary and other base systems are just for human convenience. The BS2 uses binary internally but lets us program and display other base systems to make it easier for us to read the values.
    I don't see any reason why you need to use hexadecimal in your code at all.
    Your code is really hard to read. I think the BS2 editor will automatically indent the code for you. Please do this in the future. It will make reading your code much easier. Thanks for using code tags.
    As Genetix points out your code has structural issues but then most us on the forum had structural issues with our code at one time. I hope you don't get discouraged when one of us says "you're doing it wrong". I personally learn the most from "you're doing it wrong type posts" (when directed at myself).
    I cleaned up your program as best as I could but I don't understand some portions of your code and I don't recognize any of your Serial LCD commands.
    What are SysPower, Alarm1, and Alarm2 and better explain what should happen when each state changes.
    Why do you first HIGH and LOW the Alarms and then later use PWM?
    I see you have a short and long speaker tone that I adjusted since the BS2SX is not the same speed as the BS2.
    ' {$STAMP BS2sx}
    ' {$PBASIC 2.5}
    ' Battery monitory with LCD display.
    ' ADC0831 Pins
    ' User Interface
    LCD_TX          PIN    9  ' (Changed from CON to PIN)   [LCD]
    Spkr            PIN    4  ' (Changed from CON to PIN)   [Speaker]
    SysPower        PIN    5  ' (Changed from CON to PIN)   [On or Off]
    Bat_Good_LED    PIN    10  ' (Changed from CON to PIN)   [Good Battery]
    ' Alarms
    Alarm2          PIN    11  ' (Changed from CON to PIN)   [Standby - Battery too low]
    Alarm1          PIN    12  ' (Changed from CON to PIN)   [Low Battery]
    BAUD            CON    $406E  'Set Baud rate to 19200 inverted (BS2SX)
    '  BS2 = $4020 (16416)  BS2sx = $406e (16494) [32 - 19200, True, BS2]
    ' BS2 = INT(1,000,000 / baud rate) - 20, Bits 0-11
    ' BS2SX = INT (2,500,000 / baud rate) - 20
    ' Bit 13 - Set data bits and parity, 8N = 0, 7E = 8192
    ' Bit 14 - Select polarity, True (noninverted) = 0, Inverted = 16384
    ' Bit 15 - Select driven or open output, Driven = 0, Open = 32768
    ' 16416 - 16384 = 32   (BS2)
    ' (1,000,000 / 19,200) - 20 = 52.08333 - 20 = 32   [BS2]
    ' 16494 - 16384 = 110   (BS2SX)
    ' (2,500,000 / 19,200) - 20 = 130.208333 - 20 = 110   [BS2SX]
    ' LCD Constants
    CLR             CON    012                       'LCD Clear Screen instruction (Form Feed)
    HideDisplay  CON 003                 'Hide display
    RestoreDisplay  CON 003                 'RESTORE DISPLAY
    CursorOff  CON 004                 'Turn Cursor Off
    ScrollOff  CON 020                 'Turn Scroll Off
    WrapOff    CON 024                 'Turn Wrap Off
    '  SEROUT TX, BAUD, [015,040]             'Set Contrast
    '  SEROUT TX, BAUD, [017,000,001]         'Position Cursor at Col 1 of Line 2 on LCD
    ' Speaker Constants (Converted from BS2 to BS2SX)
    Freq            CON    1500 * 0.4 ' Frequency (2.5 Hz - BS2SX, Hz - BS2)   [1 / 2.5 = 0.4]
    FreqTime1       CON    200 * 2.5 ' Duration (0.4 ms - BS2SX, ms - BS2)   [1 / 0.4 = 2.5]
    FreqTime2       CON    1500 * 2.5 ' Duration (0.4 ms - BS2SX, ms - BS2)   [1 / 0.4 = 2.5]
    ' Battery Constants (mV???)
    BatFull         CON     12000
    BatLow          CON     11800
    BatCrit         CON     11700
    BatDead         CON     11500
    ' Voltage Constants
    ' $2F10 = 12048
    ' Unknown or unused Constants
    Sdelay          CON    10 ' What is this???
    LCDVolts        VAR     Word
    batState  VAR NIB  ' Added (0 = Full, 1 = Low, 2 = Critical, 3 = Dead)
    Initialize:
      PAUSE 2000  ' Allow PC Serial Ports to stabilize
      GOSUB System_Good ' Added
      HIGH LCD_TX  ' Set pin high to be a serial port
      PAUSE 200  ' Pause for Serial LCD to initialize
      SEROUT LCD_TX, BAUD, [003]                 'RESTORE DISPLAY
      SEROUT LCD_TX, BAUD, [015,040]             'Set Contrast
      SEROUT LCD_TX, BAUD, [ScrollOff]                 'Turn Scroll Off
      SEROUT LCD_TX, BAUD, [WrapOff]                 'Turn Wrap Off
      SEROUT LCD_TX, BAUD, [CursorOff]                 'Turn Cursor Off
      SEROUT LCD_TX, BAUD, [CLR]                 'Clear Screen
    'PAUSE 5 ' Give the Serial LCD time to clear the display.
      SEROUT LCD_TX, BAUD, [LINE1]               'Goto Home Position
      SEROUT LCD_TX, BAUD, ["  Power Monitor"]   'Display Text
      SEROUT LCD_TX, BAUD, [017,000,001]         'Position Cursor at Col 1 of Line 2 on LCD
    ' 17 - Backlight on, 18 - off
      SEROUT LCD_TX, BAUD, ["     Running"]      'Display Text
      PAUSE 1000                             'Pause for 1 second
      SEROUT TX, BAUD, [CLR]                 'Clear Screen
            "ADC....  ", CR,
            "volts... "
      HIGH Bat_Good_LED ' Turn on Battery Good LED
      HIGH SysPower  ' connect or disconnect all loads
      DO ' Main Loop
        mVolts = (result */ Cnts2Mv)                ' convert to millivolts
        IF (mVolts > BatFull) THEN ' Battery is good
          IF (batState = 0) THEN ' Battery is already good
            GOSUB Prep_LCD ' Moved these 4 lines to a subroutine
            SEROUT LCD_TX, BAUD, ["Millivolts ",DEC5 mVolts]
            SEROUT LCD_TX, BAUD, ["Sys. Oporational"]
          ELSE   ' Battery has recovered
            batState = 0
            GOSUB Bat_Recover
          ENDIF ' End of inner IF Statement
        ELSEIF (mVolts < BatLow) THEN ' Changed from IF to ELSEIF
          GOSUB Low_Battery:  ' Changed from GOTO to GOSUB
        ELSEIF (mVolts < BatCrit) THEN
          GOSUB Bat_Critical:  ' Changed from GOTO to GOSUB
        ELSEIF (mVolts < BatDead) THEN
          GOSUB Emergency_stop:  ' Changed from GOTO TO GOSUB
        ENDIF ' End of outer IF statement
      LOOP ' Loop again
    Read_0831:
      LOW CS                                        ' enable ADC
      RETURN
    Prep_LCD: ' Prepare LCD to display a message (Added)
    Low_Battery:
      batState = 1 ' Low Battery
      LOW Bat_Good_LED ' Turn off Battery Good LED
        PWM Alarm1, 255, 100 ' Duty = 255, Cycles = 100 (0.4 ms - BS2SX, ms - BS2)
    ' 100 x 0.4 = 40 ms (BS2SX)
      SEROUT LCD_TX, BAUD, ["Millivolts ", DEC5 mVolts]
      SEROUT LCD_TX, BAUD, ["  Low Battery   "]
      RETURN ' Added
    Bat_Critical:
      batState = 2
        PWM Alarm2, 200, 200 ' Duty = 200, Cycles = 200
        PWM Alarm1, 255, 200 ' Duty = 200, Cycles = 200
    ' 200 x 0.4 = 80 ms (BS2SX)
        SEROUT LCD_TX, BAUD , ["Millivolts ", DEC5 mVolts]
        SEROUT LCD_TX, BAUD , [017,000,001]
        SEROUT LCD_TX, BAUD , ["Battery Critical"]
      RETURN ' Added
    Emergency_stop:
      batState = 3
      SEROUT TX, BAUD, [003]                 'Hide display
      SEROUT TX, BAUD, [ScrollOff]                 'Turn Scroll Off
      SEROUT TX, BAUD, [WrapOff]                 'Turn Wrap Off
      SEROUT TX, BAUD, [CursorOff]                 'Turn Cursor Off
      SEROUT TX, BAUD, [LINE1]               'Goto Home Position
      SEROUT TX, BAUD, ["   Battery at "]    'Display Text
      SEROUT TX, BAUD, ["  unsafe level"]    'Display Text
      PAUSE 1000                             'Pause
      PAUSE 1000
      PAUSE 1000
      FREQOUT Spkr, FreqTime2, Freq ' Changed from 1500 to FreqTime2 and from 1500 to Freq
      LOW SysPower
      HIGH Alarm2 ' Turn on Alarm
      SEROUT TX, BAUD, ["  Standby mode..."]
      LOW Alarm2 ' Turn off Alarm
      PAUSE 3000     'charge stand by      MODIFY FOR LONGER DELAY BASED ON LCD.
    Bat_Recover: ' Battery recovered from being Critical
    '    SEROUT TX, BAUD, [003]
    '    PAUSE 2500
      SEROUT TX, BAUD, [" 12 Vdc detected!"]
    '      PAUSE 2500
      RETURN ' Added
    System_Good: ' Let user know that system if fully functional (Added)
      LOW Alarm1 ' Turn off Alarms
      LOW Alarm2
      FREQOUT Spkr, FreqTime1, Freq
      RETURN
