Does anyone port MPU6050_DMP6.ino to Propeller ?
Hi!
Does anyone port Arduino MPU6050_DMP6.ino to Propeller C or Spin ?
As far as I know this code is ported to mbed and Raspberry Pi, but I cannot find the ported one to Propeller C or Spin.
If I am correct that Arduino MPU6050_DMP6.ino has not yet ported, does anyone also know the reason why ?
Kaeru no Ojisan.
Kaeru no Ojisan.
I've been interested in the MPU6050 sensor for a while and I've tried to keep track of work on drivers for this sensor. I believe there's an object in the OBEX to read from the sensor but I don't think it uses the DMP6 feature.
Weren't these ports done by the same person who wrote the Arduino code?
My guess is because it's time consuming to do so.
I know there's a program to convert C to Spin. I don't know how well it would work on the DMP6 code. I've been meaning to try it.
I've ported a few Arduino projects to Spin. Here's a link to my Spin code to interface with the inexpensive Mifare MFRC522 RFID readers.
IMO, it can be a challenge to translate C to Spin. C's pointers don't have a direct counterpart with Spin. All of Spin's local variables are longs which has tripped me up a couple of times when converting C code to Spin.
I'd think porting the code to Propeller C would be easier than porting it to Spin.
I personally decided not to spend my time on porting the code to Spin since the little Arduino Pro Mini clones are so inexpensive. I just use the small Arduino as a slave processor and have the Propeller monitor the serial stream coming from the Arduino (an idea I got from a fellow forum member).
Thank you for your quick response.
The ports to mbed and Raspberry Pi were done by the different person other than jrowberg.
I am very much interested in the idea that the Propeller monitors the serial stream coming from the Arduino, since I also know the MPU6050_DMP6.ino works on the inexpensive Da Vinci 32U board.
Kindly advise me more about the idea. Can the data from Arduino be renewed every 10ms ?
Kaeru no Ojisan
The Arduino didn't seem to have trouble with 115200bps even at 8MHz. I imagine it's reading the sensor at a slower frequency than it would with a 16MHz Arduino but I think the bottleneck is the data flow at115200 baud and the Spin code used to manipulate it.
I don't know if the data can be renewed at 10ms or not. I imagine it depends on what sort of data you have it send. I've just played with the default data myself.
I've purchased MPU6050 sensors a couple of times off ebay. The last time I purchased some was from this seller. The one (of two) I've tried appears to work fine.
The 3.3V board looks much better.
I also want to know how to connect Arduino and Propeller, and example Spin code.
Kaeru no Ojisan
Connecting the Arduino to the Propeller is trivial. The "TXO" on the Arduino connects with any I/O pin on the Prop you choose to receive the serial stream on. A wire should be fine but if you want to be really safe you could use a 100ohm resistor in series. The "RXI" on the Arduino connects with any Propeller I/O assigned as the transmit pin.
I don't have any example Spin code yet. My intention is to replace (or augment) the HMC58853L in this project with a MPU6050. I doubt I'll have time to do this until next week.
I'm pretty sure I'll attempt to translate the DMP6 code to Spin but I don't know how soon that will be.
I am very glad to hear that.
I will expect you both of your attempts, and watch your progress.
Kaeru no Ojisan
