MAX1497 ADC and Propeller Quick Start
Anyone out there who can help me with this setup? I am exausted trying.
Data Sheet ... http://datasheet.electronicafacil.net/MAXIM/MAX1497.pdf
The code seems to be alright I think......
CON
_clkmode = xtal1 + pll16x 'Standard clock mode * crystal frequency = 80 MHz
_xinfreq = 5_000_000
CS = 11 ' Chip Select
Clk = 9 ' Clock
DOut = 8 ' DataOut
DIn = 10 ' DataIn
Cnts2Mv = $001F
OBJ
pst : "Parallax Serial Terminal Plus"
BS2 : "BS2_Functions" ' Create BS2 Object
VAR
Long wresult1, wresult2, wValue ' Conversion Result
Word Volts ' Result --> mVolts
Word Value ' Result --> Value
Byte Status, rFlag
PUB Main
pst.Str(String(2,1,1,"ADC CH 0: ",2,1,2," Raw : Volts"))
dira[CS]~~
outa[CS]~~
outa[CS]~ ' Enable ADC
BS2.SHIFTOUT (DIn, CLK, BS2#MSBFIRST, 8, 130) ' Enable Write to Control Register %10 00001 0
BS2.SHIFTOUT (DIn, CLK, BS2#MSBFIRST, 16, 24576) ' Enable bit ON ,RANGE = 2.0 Volts %0110000000000000
repeat
MAX1497
PRI MAX1497
'outa[CS]~ ' Enable ADC
Status := 8
repeat while Status == 8
BS2.SHIFTOUT (DIn, Clk, BS2#MSBFIRST, 8, 192) ' Command Read Status Register 100000000
Status := BS2.SHIFTIN (DOut, Clk, BS2#MSBPOST, 8) '^
rFlag := (Status & %00001000) '|
pst.Str(String(2,12,9,"Not Ready")) '|
waitcnt(clkfreq+cnt) '|
'└── Repeat untill Status 0(Data valid in ADC Result)
BS2.SHIFTOUT (DIn, Clk, BS2#MSBFIRST, 8, 208) ' Enable READ ADC Result Register 1 (12 MSBs) %11010000
wresult1 := BS2.SHIFTIN (DOut, Clk, BS2#MSBPOST, 12)
BS2.SHIFTOUT (DIn, Clk, BS2#MSBFIRST, 8, 232) ' Enable READ ADC Result Register 2 ( 8 LSBs) %11101000
wresult2 := BS2.SHIFTIN (DOut, Clk, BS2#MSBPOST, 8)
pst.Str(String(2,12,9," READY "))
'outa[CS]~~ ' Disable ADC
wValue := (wresult1 << 8) + wresult2 'Combine Result 12 Bit REG A + 8 Bit REG B
Volts := wresult1 / Cnts2Mv
pst.Str(String(" ",2,7,3))
pst.dec(wValue)
pst.Str(String(" ",2,18,3))
pst.dec(Volts)
PLEASE anyone who can help PLEASE
I notice you set the chip select (CS) line low but as the code is now, it was never high. Most SPI deices need the CS line to transition from high to low in order to enable the chip.
When you say "the code seems to be alright", why do think so? Did you write if yourself of did you get it from someone who said it works?
A photo of your setup may also be a good idea.
