Diptrace help please?
Heya all,
I'm just getting started using DipTrace and I am trying to figure out what I'm doing wrong here.
My attachment is the schematic that I'd like to turn into a board with 2 signal layers, a ground plane and a power plane (3.3v)
The schematic has no errors, and when I use it to create a PCB it lays everything out fine.
However- it routes traces for Vcc and Gnd to each component on the signal layers.
Can someone explain what I need to do to make the Vcc and Gnd connections connect directly to a 3rd and 4th plane (Vcc and Gnd?) This should eliminate the traces.
Thanks in advance!
Robert
Thanks in advance!
Robert
It is limited to 2 signal layers. I can't find any reference to Ground and Power layers.
I got a "wrong format" error when I tried to open the file. I have a Standard license myself so I'd think it would be able to open a file created by the free version. The version # on mine is 2.2.0.2. I wonder if I need an update in order to open your file?
I've not done Power/Ground planes with this software before. Time to learn!
diptrace how to multi layer
First result will probably be a post on the Diptrace forums that has a response from their tech support guy Alex.
If that doesn't work I'd probably look for more help on the Diptace forums.
First the free version is "All features and libraries, 300 pins and 2 signal layers, non-profit use only"
Second, even if you could do 4 layers, are you sure you want that? It's more expensive and you will not be able to do a DIY board. Is that what you really need?
I usually approach it in this order:
1 - Make first attempt to define board size
2 - Work the component placement according to schematic/connector needs
3 - Try 1 layer routing
4 - If after "N" attempts (depending on schematic compplexity and max board size requirements) I don't succeed then try 1 layer + jumpers on second layer.
5 - If not possible revert to 2 layer design
Alex
I think there are reasons to use ground and power layers other than to aid in routing paths for these traces. I believe these layers benefit PCBs by reducing noise and keeping the power clean.
I've only created pcb with ExpressPCB which is incredibly simple to use, and creating the power and ground planes is very straight forward. Diptrace, so far seems like it's a much better software package and incredibly useful. I wish I had more time to learn it, but for now I'm somewhat limited (hence my question.)
The biggest advantage to having separate power and ground planes is minimized routing on the top and bottom signal planes. But the other great advantage is being able to "tap" power or ground from anywhere on the board, wherever you need it-without using real estate for the trace to get it there.
Rick sand Dave- thanks! I'mma keep trying. It can't be that difficult. I must be overthinking it or something.
Publison- if you figure it out, lemme know! I'll be sure to post any tidbits I figure out.
Doesn't sound too hard, have you tried it?
I just got back to my computer and tried it. Perfect! Thanks tons
A few more hints and tips to go with this:
-When you use Schematics to "Convert to pcb" you should take the following steps in order:
1- arrange the components (manually or automatically) for the board layout.
2- Create the power and ground planes and select the net to connect to the plane at the time of creation (this is done BEFORE using auto-route.)
3- Perform auto-route last. For whatever reason, if you don't, it can throw some errors. Not sure why.
I've found the following additional hints and tips to be useful
I had zero time last night to try the suggestions. I will have zero time until the weekend.
USE KiCad
Opensource , no limitations . what else need i say
http://www.kicad-pcb.org/display/KICAD/KiCad+EDA+Software+Suite
