Prop2 Analog Input range — Parallax Forums
TubularTubular Posts: 4,774
edited 2014-06-23 20:37 in Propeller 2
I've been playing around with a sensor whose output swings down just below zero volts, by up to a diode drop or so
I believe the analog input operation on Prop2 was going to be setup such that 75% of the range covered 0 to 3.3v, so it would be great if the input does indeed go down to -0.8v
Is this still "the plan", or does the synthesis now mean we'll be looking at a more standard range of 0...3.3v (only)
  • jmgjmg Posts: 15,200
    edited 2014-06-22 22:21
    As far as 800mV would be unlikely, as there will always be parasitic diodes present.
    A couple of hundred mV is all most Silicon devices promise, and then they spec best linearity inside the rails.
  • TubularTubular Posts: 4,774
    edited 2014-06-22 22:32
    Few hundred mV would be fine. Am using 300mV range on the multimeter, it hasn't "clocked it" yet...
    edited 2014-06-23 17:03
    In delta-sigma ADC mode, a pin's IN bit reads ~12.5% duty at GND and ~87.5% duty at VDD (ideally 3.3V).
    So, 0% duty should indicate around -0.4125V and 100% duty should indicate about 3.7125V.
    There are calibration modes while in ADC mode: if DIR bit = 1, then OUT bit = calibrate low/high. These connect the ADC input to GND or VDD via identical switches and current-limitting resistors that normally connect the ADC input to the pin. So, GND/VDD calibrations should be very accurate.
    edited 2014-06-23 17:14
    cgracey wrote: »
    What is the input impedance of the ADC at 0.0V,3.3V and at -0.4125V, 3.7125V. (at elevated temperatures) ?
    What is the expected tolerance on that ?
    edited 2014-06-23 17:57
    jmg wrote: »
    Impedance is ~5 megohms. Tolerance is probably +/-10%, based on process conditions. Impedance would increase with temperature, too.
    Thanks Chip
    I'm guessing the impedance won't be that high near the extremities as the diodes kick in, but thats ok (useful for clamping, even).
    It'll be a bit like the old Intersil CA3140 that still worked down to a bit below the negative rail... neat
