Propeller Connection Question — Parallax Forums
NWCCTVNWCCTV Posts: 3,629
edited 2014-06-28 11:10 in General Discussion
I am trying to breadboard a Propeller Chip (http://www.parallax.com/product/p8x32a-d40)
for testing purposes and I am running in to issues. Can I temporarily leave the EEPROM disconnected and only connect the prop chip just for troubleshooting? Will it show up in Tools/Identify Hardware if my connections are correct?
    edited 2014-06-21 15:52
    I'm almost 100% sure it will show up. IIRC the first thing the boot procedure checks for is a serial connection, and tries to download from that first. That's how you can download to ram and run the program.
    edited 2014-06-21 16:10
    NWCCTV wrote: »
    It will run without the EEPROM. Just make sure you have all power and ground connections for ALL VDD and VSS, and that the Crystal is as close as possible to the chip.
    And decoupling caps at power connections.
  • NWCCTVNWCCTV Posts: 3,629
    edited 2014-06-21 17:14
    I am using an EBay breadboard power supply which supplies 3.3V or 5V. I have everything hooked up including the EEPROM. I am able to load a program to EEPROM with no issues. However, I can not light an LED coming off any of the pins.
    edited 2014-06-21 17:22
    I doubt disconnecting the LED EEPROM will solve things.
    You should post the code you're using. How is the LED connected?
    Have you tested the LED with a 3.3V source on its own?
    Edit: I meant EEPROM in the first line not LED.
    edited 2014-06-21 17:30
    Wow.
    Power to both sides of the Prop?
    Decoupling capacitors across the power at the chip?
    Crystal nearby?
    Are you getting good voltages (where you expect them) off your breadboard power supply?
    Is it a known good Prop? (OK, sometimes this is hard to guarantee :smile:)
    Are you setting a clock in your test program or just using RCFAST?
    Does your test program blink an LED on another Prop board? (It's on my checklist...I've been known to make coding errors)
    It should work unless you somehow fried it from the start.
    I run them without crystals and EEPROMs often so it is certainly a workable plan.
    edited 2014-06-21 17:31
    I am pretty sure it is a power issue. I am bread boarding off of what I think is the incorrect pdf. The one I am using does not show the voltage regulator connections. I know there is a step by step pdf somewhere but I just can not locate it.
    edited 2014-06-21 21:15
    I am going to set this project aside until I get one of the breadboards that is included in the PE kit. It uses 6 holes instead of the standard 5 that most bread boards use. Although I could use jumper wires to accomplish what I need to do, it would make for quite a bit of a mess of wires which I do not like doing. Will order the bread board and also make a suggestion to Parallax for a Prop "Kit".
  • GenetixGenetix Posts: 1,758
    edited 2014-06-22 03:18
    Parallax has already kitted all the parts needed to do the same set-up as the PE Kit.
    http://www.parallax.com/product/130-32305
    I think this is what you are thinking of and years ago Parallax sold it as a kit.
    http://www.parallax.com/product/32210
    edited 2014-06-22 12:14
    Yes and no on the first one. There is no PCB. I think that would make for the perfect kit. I do like the prop stick but a little pricey for what it does.
    edited 2014-06-22 13:23
    Andy,
    Do you mean something like this?
    Wulfden Propeller Platform Through Hole Kit
    Brian still makes them. He's a good guy and has good stuff. (Plus he speaks Forth!)
    edited 2014-06-22 17:24
    @mindrobots, That is what I was talking about. If Parallax were to make them I am pretty sure they could get the price down. I know a lot goes in to them but that price seems a bit steep to me.
  • JLockeJLocke Posts: 354
    edited 2014-06-22 22:26
    I recently posted a board that I use for prototyping in the Projects sub-forum. I've sent a few of these out with "The Fellowship of the Travelling Parts Box" from Chris Savage's web site (www.savagecircuits.com). Plugs into the edge of your breadboard and brings out all the I/O lines. Also provides regulated +5VDC to the breadboard.
    edited 2014-06-23 18:29
    I have not seen one in the box so they must have been gone by the time I received. Anyhow, for this particular project I was thinking of I may just go with a Prop mini due to the size.
  • WBA ConsultingWBA Consulting Posts: 2,934
    edited 2014-06-23 20:36
    My M44D40+ and PowerTwig combo makes the PE Kit setup a breeze. (see this post) Let me know if you would be interested; $22 gets you both shipped and I am pretty sure I have both in stock right now. (I recently organized my garage so I need to find that box....) If not, it only takes me a couple days to make a batch of both. I don't really market them, but still make and sell them about once a month for a few repeat customers.
    edit: this is the true PE Kit setup:
    The PCB also works for a DIP40 Propeller chip as well if you use stacking headers and omit the QFN Propeller. I always meant to sell that as a bare bones kit, but since my profit is already essentially zero, I haven't done anything with that idea.
    730 x 1024 - 420K
    1024 x 719 - 272K
    1024 x 664 - 352K
    edited 2014-06-26 20:07
    I have everything I need for the PE Kit setup except the 6 pin bread boards. Curious as to why those were chosen instead of the standard 5 pin boards. Like I said before, I could use jumpers but after attempting that I got too frustrated. I am only able to find the breadboards on Parallax's web site. Nothing on EBay. I will probably order the next time I place an order for other items.
  • RDL2004RDL2004 Posts: 2,554
    edited 2014-06-27 08:16
    Do any of the circuits used in the PE Kit actually require a six hole breadboard? I went through a lot of that book a couple of years ago and I don't remember having any major problems using a normal five hole type breadboard.
    edited 2014-06-27 12:08
    Yes, Pg.34 http://www.parallax.com/sites/default/files/downloads/122-32305-PE-Kit-Labs-Fundamentals-Text-v1.2.pdf
    edited 2014-06-27 13:18
    I also wondered what parts of the PEK needed all six holes.
    The only example I see on page 34 is the part with the push button. The push button on the far right breadboard could easily span the center divide and components connected to row 28 could be moved to row 29. I couldn't find any obvious problems with using five hole breadboads with the PEK.
    edited 2014-06-27 13:23
    None of the rows in that picture have all 6 holes used. The most I see is one with 4 holes in use. It might be a bit tight, but hat circuit can be built on a standard 5 hole board.
    edit: I see where the pushbutton in the bottom right would have to be rearranged though. It wasn't real obvious at first which holes it was pushed into. That type of button is a pain to use on any plastic breadboard. The leads are wide and flat, they just never fit tight.
    edited 2014-06-27 15:06
    OK, I agree, brain fart on my part. However, It would still be easier to follow the schematic with the same type of bread boards. Some times my ADD gets the best of me and I can make a real mess of things. I have 3 boards coming so no worries!!!
  • ajwardajward Posts: 1,130
    edited 2014-06-28 04:32
    I moved my PE kit to a larger, 5 hole, breadboard. I needed more real estate to play with. :-)
    1024 x 1365 - 103K
    edited 2014-06-28 10:47
    I have several "breadboad friendly" Props. I used to use these frequently when testing sensors on a breadboard.
    All 32 I/O pins were available and the Propeller took up minimal board space.
    Since the QuickStart has come out, I very rarely (if ever) use the above board (or ones like it) since I just set the QuickStart next to the breadboard and plug the wires into the QuickStart header. This way no breadboard realestate is used by the Propeller.
    As long as the circuit doesn't require much current, I use the QuickStart's Vin pin for a 5V source and the Vdd line for a 3.3V source.
    I have a bunch of QuickStarts I keep around for this sort of thing.
    The Photo above used a small PCB SparkFun used to sell. Before making the board pictured above, I made one with a DIP chip.
    It looks hideous but it works. The white header at the bottom of the board is for a Prop Plug and the black monstrosities near the top are heat sinks attached to the 5V and 3.3V regulators.
    With the QuickStart, I often don't even use a breadboard. I just plug stuff directly into the QuickStart header.
    IMO, the QuickStart has really made prototyping with the Propeller very simple.
    648 x 505 - 635K
    703 x 498 - 810K
    575 x 708 - 876K
    678 x 553 - 772K
    617 x 538 - 692K
    @Duane, That is a good idea for prototyping. I was attempting to use the breadboard method so I could figure out just how small I could get my board. I need a small footprint for one of my projects but I think the Schmartboard will fit the bill.
