"Tippi" it is — Parallax Forums
"Tippi" it is
ajwardajward Posts: 1,130
edited 2014-06-27 20:54 in Robotics
Woke up at oh-dark-thirty and decided to take a bit of time looking at the Toddler. As I feared one of the batteries had started oozing its crud. Tossed all those in the bin, thoroughly cleaned the contacts and put in fresh batteries in.
Out of curiosity, I turned on the power switch to see if anything happened. Lo and behold, she lurched a bit to one side and started walking! (Backward I think!, but walking nonetheless.)
It was at this point her name came to me. In the process of ambling across my small table, she kept making this unnerving tilt to the right. Film at 0115!
https://www.youtube.com/watch?v=EC4i4uX0j1M&feature=youtu.be
I apologize for the dim picture, but my film studio isn't very well lit in the middle of the night. At this point, I don't know if the excessive tilt is because of the program or the alignment of the linkage. But as we get to know one another, things will get sorted out.
Powering down for the night.
Amanda... and Tippi. :smile:
    edited 2014-06-20 06:56
    The crowd roars and chants "Figure eight, figure eight."
    edited 2014-06-20 08:22
    Tippicanoe and AJ too! http://en.wikipedia.org/wiki/Tippecanoe_and_Tyler_too
    Lovin' it. You can def fix that "listing to port" with either (or both) mechanical/software tweaking.
  • WhitWhit Posts: 4,191
    edited 2014-06-20 19:23
    Love the name! You are the best at naming your bots...
    Did Tippi come with the manual. You can find a pdf by googling Parallax Toddler pdf.
  • ajwardajward Posts: 1,130
    edited 2014-06-21 03:35
    Following a short nap after my second assignment tonight, it was time to sort out Tippi's worrying tipping. I tried adjusting the servo horn with very little success. Nothing I changed in the program seemed to work!?!?!
    Went to the kitchen for a cup of coffee, came back and just stared at the little beastie. Then, in a flash of caffeine induced clarity, it occurred to me... never trust anyone else's work! I checked the software and manual... and "Ah jeez, you didn't?" Yep, the stride and tilt servo cables were reversed. The eBay listing said the Toddler "has not been used much". Yeah, I can see a reason why.
    Anyhow, I put the cables back where they were =supposed= to be, made some slight changes in the demo code and Tippi's tipping is nicely balanced.
    :cool:
    Now to work on that figure eight!
    edited 2014-06-21 03:36
    Whit wrote: »
    Thanks whit! :-)
    I did find the manual and lots of demo code. Fun will be had!
    edited 2014-06-21 03:41
    Indeed! The problem turned out to have a simple fix... once the actual problem became clear. I was so fixed on the tilt issue, I didn't notice the stride was changing.
    All better now!
    edited 2014-06-24 20:22
    Took a bit of time this evening tweaking Tippi's gait and found, not surprisingly, walking is a whole lot easier on a hard floor as opposed to carpet... most of our apartment.
    I think a Toddler attempting to traverse a carpeted floor might be better called a Toppler. :smile:
    Anyway, it's ball to work with.
    edited 2014-06-26 16:36
    I got Tippi working well and I wanted to post a video...
    [video]https://www.flickr.com/photos/81065424@N00/14329301329/[/video]
    edited 2014-06-26 16:50
    ajward wrote: »
    Looks great!
    Not quite a figure eight. :)
    I should talk. My Blue and Gold have not seen the light of day for a year now. :(
    Jim
  • NWCCTVNWCCTV Posts: 3,629
    Good job.
    I know the feeling. I have a penguin with the same issue
