Pausing the propeller in execution and using an external oscillator. — Parallax Forums
__red____red__ Posts: 470
edited 2014-06-21 06:58 in Propeller 1
If I run a propeller using an external oscillator, say for example an output from another prop... if I stop the clock as it were, will the prop just hold and step slowly if I pulse slowly?
Red
  • jmgjmg Posts: 15,200
    edited 2014-06-19 21:15
    __red__ wrote: »
    Yes, it is a static CMOS part - just make sure no glitches can occur on the CLK.
    Another prop should be fine.
  • LawsonLawson Posts: 870
    It should, as long as you're not using any of the PLLs.
    Marty
