Active Bot startup
Hi I installed the Active bot.. and ran the Initial test file to moved the wheels and only P27 kept on lighting up. I have checked the connections and will move the motors to the bottom of the body as recommended.. Are there any other troubleshooting you can recommend besides checking the restors
regards
Ziyad
regards
Ziyad
will do.. One quick question? There is only one way the wire gets plugged into the sensor? It is grooved to insert in one way only.. Just wanted to double check
That's not the case for the other end of the cable, where it plugs into the Activity Board's servo headers. For P14 and P15, make sure the black wire is closer to the breadboard and the white wire is closer to the edge of the board.
