flash LED wirelessly .... please help :( — Parallax Forums
ZakariyaZakariya Posts: 3
edited 2014-06-21 11:55 in BASIC Stamp
hi every one
i am new for BS microcontroller
i work on project that flash LEDs wirelessly (xbee ) using IR sensor
to make my explaination simple see digram below
..................transmitter.........................................receiver.....................
IR sensor ==> BS2 ==> Xbee ................. Xbee ==> BS2 ==> LEDs
i built sketch for both the receiver and transmitter so :
when the sensor 1 detect ... led 1 will shutdown
when the sensor 2 detect ... led 2 will shutdown
________________________
the problem now is when both sensor detect one of the LED will shutdown only
i think the problem with sketch of the receiver......please help
this is my sketch for transmitter
' {$STAMP BS2}
' {$PBASIC 2.5}
ir_detect VAR Byte
LOW 7
DO
DEBUG CLS
ir_detect = IN8
IF (IN8 = 0 ) THEN
DEBUG "Output 8 is high, no object detected." ,CR
ELSE
DEBUG "Output is 8 low, object is detected. " ,CR
SEROUT 14, 84, ["A"]
ENDIF
ir_detect = IN9
IF (IN9 = 0 ) THEN
DEBUG "Output 9 is high, no object detected." ,CR
ELSE
DEBUG "Output 9 is low, object is detected. " ,CR
SEROUT 14, 84, ["B"]
ENDIF
ir_detect = IN10
IF (IN10 = 0 ) THEN
DEBUG "Output 10 is high, no object detected." ,CR
ELSE
DEBUG "Output 10 is low, object is detected. " ,CR
SEROUT 14, 84, ["C"]
ENDIF
ir_detect = IN11
IF (IN11 = 0 ) THEN
DEBUG "Output 11 is high, no object detected." ,CR
ELSE
DEBUG "Output 11 is low, object is detected. " ,CR
SEROUT 14, 84, ["D"]
ENDIF
PAUSE 1000
LOOP
............................................receiver............................................
' {$STAMP BS2}
' {$PBASIC 2.5}
x VAR Byte
LOW 7
DO
SERIN 14, 84, [ x]
DEBUG ? x
IF (x= 65) THEN
LOW 8
ELSE
HIGH 8
ENDIF
IF (x= 66) THEN
LOW 9
ELSE
HIGH 9
ENDIF
IF (x= 67) THEN
LOW 10
ELSE
HIGH 10
ENDIF
IF (x= 68) THEN
LOW 11
ELSE
HIGH 11
ENDIF
PAUSE 250
LOOP
END
  • stamptrolstamptrol Posts: 1,731
    edited 2014-06-19 05:55
    Welcome to the forums!
    Assuming the transmitter program is behaving as you expect, you should be able to see the data activity lights on the XBee's as the data is sent from the transmitter to receiver.
    On the receiver Stamp, there is no communication buffer so the SERIN must be occurring at the instant the data arrives from the transmitter. We can get around that problem by using the WAIT modifier in the SERIN command. This will force the SERIN to wait for some period of time as it executes so that there is a much better chance for the transmitted character to arrive. If you look at the Helpfile under SERIN, there is a detailed explanation of the modifiers available to use for serial communication.
    Cheers,
  • ZakariyaZakariya Posts: 3
    edited 2014-06-19 07:36
    stamptrol wrote: »
    Cheers,
    thanks for replay
    I check that before but I got error may be I misunderstand :( ........
    actually I did some modification on program
    for transmitter
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    ir_detect1 VAR Byte >>>>>>>'sensor 1>>>>>'LED1
    ir_detect2 VAR Byte>>>>>>>'sensor 2>>>>>'LED2
    ir_detect3 VAR Byte>>>>>>>'sensor 3>>>>>'LED3
    ir_detect4 VAR Byte>>>>>>>'sensor 4>>>>>'LED4
    LOW 7
    DO
    DEBUG CLS
    ir_detect1 = IN1
    IF (IN1 = 0 ) THEN
    DEBUG "Output 1 is low, no object detected." ,CR
    ELSE
    DEBUG "Output is 1 high, object is detected. " ,CR
    ENDIF
    ir_detect2 = IN5
    IF (IN5 = 0 ) THEN
    DEBUG "Output 5 is low, no object detected." ,CR
    ELSE
    DEBUG "Output 5 is high, object is detected. " ,CR
    ENDIF
    ir_detect3 = IN8
    IF (IN8 = 0 ) THEN
    DEBUG "Output 7 is low, no object detected." ,CR
    ELSE
    DEBUG "Output 7 is high, object is detected. " ,CR
    ENDIF
    ir_detect4 = IN10
    IF (IN10 = 0 ) THEN
    DEBUG "Output 10 is low, no object detected." ,CR
    ELSE
    DEBUG "Output 10 is high, object is detected. " ,CR
    ENDIF
    PAUSE 1000
    LOOP
    ****************************************************************for receiver**********************************************************
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    x1 VAR Byte >>>>>>>'sensor 1>>>>>'LED1
    x2 VAR Byte >>>>>>>'sensor 2>>>>>'LED2
    x3 VAR Byte >>>>>>>'sensor 3>>>>>'LED3
    x4 VAR Byte >>>>>>>'sensor 4>>>>>'LED4
    DO
    SERIN 14, 84, [x4]
    IF (x4= 65) THEN
    HIGH 1
    ELSE
    LOW 1
    DEBUG "active",CR
    PAUSE 1000
    ENDIF
    SERIN 14, 84, [x1]
    IF (x1= 66) THEN
    HIGH 5
    ELSE
    LOW 5
    DEBUG "active",CR
    ENDIF
    SERIN 14, 84, [x2]
    IF (x2= 67) THEN
    HIGH 7
    ELSE
    LOW 7
    ENDIF
    ' SERIN 14, 84, [ x3]
    'DEBUG ? x3
    'IF (x3= 68) THEN
    'HIGH 10
    'ELSE
    'LOW 10
    'ENDIF
    PAUSE 1000
    LOOP
    END
    the output behavior now is
    >>>>>>> when sensor 4 is detect..... LED 4 is off ( this is what I want for other sensors.... when they detect object ... the LED of sensor in receiver should go off )
    >>>>>>> when sensor 3 is detect..... LED 4 and 3 is off
    >>>>>>> when sensor 2 is detect..... LED 4 , 3 and 2 is off
    >>>>>>> when sensor 1 is detect..... LED 4 , 3 ,2 ,1 is off
    can any one tell me why outputs are coming like this??? ..... and how to fix the sketch what to add and what to remove?????
    I am still beginner ):
    edited 2014-06-19 08:47
    My first question always has to be, which XBee model are you using? Is it new, or is it one that has already been used in other projects? Is it series 1, 802.15.4?
    In your transmitter/receiver program, things will be easier if you can consolidate the state of all the detectors into one byte.
    For example...
    ir_detect VAR Byte
    ir_detect.bit0 = IN1
    ir_detect.bit1 = IN5
    ir_detect.bit2 = IN8
    ir_detect.bit3 = IN10
    DEBUG "Output outputs are", BIN4 ir_detect ,CR
    SEROUT 14, 84, [ir_detect]
    Then on the receive side, there is only one byte wait for, and the program there can decode it bit by bit.
    edited 2014-06-19 12:29
    Another thing, the consolidation of the detected inputs into one byte can be much easier if you have all the inputs on neighboring pins, such as in0 to in3. Then the program can read them all at once and it becomes,
    [SIZE=2][FONT=courier new]ir_detect VAR Byte
    ir_detect = INA       ' read all 4 inputs at once from in0..in3
    SEROUT 14, 84, [ ir_detect][/FONT][/SIZE]
    thanks a lot Tracy for your replays ...... now it works ....... I will post the project after I finish to make clear for all the people who seek for the same solution
    thanks a lot to Stamptrol too
