What is the latest best option for board houses? — Parallax Forums
idbruceidbruce Posts: 6,197
edited 2014-06-18 05:36 in General Discussion
I know this subject has been covered several times, but things change, especially during and after a recession.
I have a small 2 layer board (1.3" X 1.2") that I want to have made, with blue solder mask and 2 oz. thickness, and I only need one or two boards, but I realize that I will probably have to pay for more boards.
I would go for OSH Park, but it appears that they do not offer 2 oz. copper boards.
Basically, I am just wondering if there is a better alternative than ITEAD Studio. For (10) - 5CM X 5CM 2 layer, 2 oz. copper, with blue solder mask, they want $40. And to be honest, I am not sure if that is blue solder mask or just the color of the PCB material.
  • LeonLeon Posts: 7,620
    edited 2014-06-17 01:57
    The colour of the PCB depends on the solder mask.
  • idbruceidbruce Posts: 6,197
    edited 2014-06-17 04:31
    Thanks Leon
    I think I will give ITEAD a try.
    edited 2014-06-17 05:28
    I've been very pleased with their service.
    edited 2014-06-17 08:38
    Leon
    On a whim this morning, I decided to attempt to redesign my board to be single sided, and I succeeded. Since I no longer need through hole plating, I have decided to attempt to make it myself, according to previous discussions between you and I.
    However I think ITEAD is probably the best I found for 2oz. copper. Odds are that I will use their services in the future. Perhaps sooner than I think, if I fail to make a decent board :)
  • jazzedjazzed Posts: 11,803
    edited 2014-06-17 09:19
    Hi Bruce,
    Just curious. Why do you need 2oz copper?
    edited 2014-06-17 09:26
    Hey Jazzed
    I need 2 oz. copper because it is a very small board (1.2875" X 1.2") and I need high amperage (15 - 20A), with a lot of through hole components crammed into that small board.
  • GenetixGenetix Posts: 1,772
    edited 2014-06-17 13:15
    That's a lot of power. Have you factored In heat dissipation and is that board flameproof should something catastrophic happen?
    edited 2014-06-17 13:30
    If it's a one off, you could use 1 oz copper and solder pieces of copper wire to the high current tracks. I've done that in that past, and it worked very well.
    edited 2014-06-17 15:08
    Leon
    Yea, I was considering that option earlier when I could not get all the tracks down, then I decided on a jumper, and then I figured out the necessary routing to get the amperage up with 2 oz. And since then, I figured out the routing for a single layer board, so as mentioned, I plan to try the board in house. I have a bunch of 2 oz. presensitized boards left over from my experimentation with the exposure cylinder and etching table.
    I think it will be pretty easy, but then again, it has been a couple years since I have messed around with it. I will have to go back and review some of my notes.
    edited 2014-06-17 15:15
    Genetix
    Yep..... That is a lot of power, and it is going to be attached to a Propeller Proto Board :)
    Flameproof? :)
    As long as my Proto Board doesn't go 'poof', I think it will be alright, however I will have to study IRF3708 documentation about heat disapation.
    edited 2014-06-18 03:44
    There's a board house in Elk Grove Village that the local Chicago guys prefer. They will also do pick and place, i think you have to supply the components. They accunulate orders, then build a whole slab at once. I think the longest wait is 2 days. Ask on Pumping Station 1 and Workshop88 mailing lists.
    edited 2014-06-18 04:36
    idbruce wrote: »
    Leon
    If it's that old, it probably won't work properly. I've had problems with material more than six months old.
    edited 2014-06-18 05:07
    Leon
    Yea, we have had this discussion before :)
    It has been sitting for quite some time.... The boards are well sealed and lightly packed, so I am hoping that they will be alright and I will certainly be keeping my fingers crossed. As you know, it is no major ordeal to expose and etch a board, so I am at least going try.
    The biggest problem is just cleaning up from all the other projects, to get ready for this one. I made the positive film last night, and this morning I will be cleaning out the trays, wiping down the work area, etc... I figure about an hours worth of work and the work space should be ready.
    Setting up a custom size plate and cutting the board should be about another hour and a half, because all the necessary equipment and materials are in such disarray.
    So about 2-1/2 hours worth work, and I should be ready to make an exposure.
    I just need one small section of board that has remained in tact all this time.
    Leon
    Not that you are particularly interested, but here is the board that I will be attempting to make. And yes, I know the artwork is to close to the edge of the board :) The positive film has been increased in size to allow 1/8" extra on all sides and I will trim the board back down to it's intended size after etching.
    The board will hold (3) - IRF3708s and mount to the SVGA port area of the Prop Proto Board. As mentioned earlier, the final size will be 1.2875" X 1.2".
