bs2 help
Hi! everybody I,m trying to use the bs2 with the speak jet to say the temperature number and also the time .
I,m using the ds1620 and the ds1302. Any help with this will be great!
Welcome to the forum!
Try and narrow down each block and get them working individually:
BS2 and 1620:
http://www.phanderson.com/stamp/ds1620_1.html
BS2 and DS1602:
http://www.phanderson.com/stamp/time_keeping/ds1602_1.html
BS2 and Speakjet:
https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1CHFX_enUS573US573&ion=1&espv=2&ie=UTF-8#q=Speakjet+BS2&safe=off
I'm sure others have codes that they might share. I haven't done anything with the SpeakJet.
http://isl.ecst.csuchico.edu/DOCS/Robots/Parallax/BoeBot/Code/Resources/Application_Kits/ds1302_real_time_clock/DS1302_Real-Time_Clock.pdf
http://www.rambal.com/descargas/libros/Nuts and Volts/1/It's Time to Get Real Using the DS1302 Part 1.pdf
http://www.rambal.com/descargas/libros/Nuts and Volts/1/It's Time to Get Real Using the DS1302 Part 2.pdf
DS1302 code (first one)
http://www.parallax.com/downloads/ds1302-basic-stamp-sample-code
Using the DS1620 with the BS2
http://www.robotshop.com/media/files/PDF/appkit-ds1620-digital-thermometer-604-00002.pdf
http://www.rambal.com/descargas/libros/Nuts and Volts/1/Thermometer on a Chip.pdf
Does anyone else a know a place to gets the remaining Nuts & Volts and the Appkit code?
This project uses the DS1302 and DS1620.
http://www.savagecircuits.com/content.php?71-Binary-Digital-Clock
DS1302 Demo code
http://www.savagecircuits.com/content.php?69-DS1302-Demo-Code
This also uses the DS1620 and DS1302
http://www.savagecircuits.com/content.php?68-Digital-Thermostat
Welcome to the Forums, Latan Pace. Have you gotten the BS2 to work with anything individually yet (either the Speakjet, the ds1620 or 1302)? That's your first hurdle, just making sure all of your hardware connections are good so you can read both modules and speak.
If you don't have the TTS256 chip, you might want to consider purchasing the RoboVoice chip rather than the TTS256 since RoboVoice costs less than TTS256 and does the job of both the SpeakJet and the TTS256. As you can see from the video on the RoboVoice product page, it works well with the BS2 (the BOE-Bot video was made by erco).
number I would love to see it! And Thanks and advance.
I've only used the SpeakJet with the Propeller. I don't have any examples for it using the Basic Stamp.
Do you have the individual components working? If you've made a custom board you should still test the individual components with existing test code to make sure they work alone before trying to integrate them.
An economical alternative to a $49 BS2 + $60 Emic-2 plus RTC and temp sensor.
The large LCD display and 7-color internal LEDs are a bonus.
To paraphrase Davy Crockett - Make sure you(and your equipment and connections) are right and then go ahead on.
Tim
History repeats itself because nobody was listening the first dozen or so times.
