QuickStart measure volts
Kaeru no Ojisan
Hi, I am a newcomer for this forums and a quite beginner for propeller.I bought Propeller P8X32A QuickStart recently and started Propeller C Tutorials.
Please refer to Propeller C - Simple Circuits - Measure Volts.
I would like to do this using QuickStart rather than Propeller Activity Board.
Kindly advise me how to circuit and how to amend the code.
Thanks Kaeru no Ojisan
Welcome to the forums !
The Quickstart board does not have an Analog to Digital converter like the Activity Board, which has a
http://www.digikey.com/product-detail/en/ADC124S021CIMM%2FNOPB/ADC124S021CIMM%2FNOPBCT-ND/755114
The Quickstart does have provisions to do Delta Sigma A/D with to addition of a few passive components. See:
http://www.parallax.com/sites/default/files/downloads/40000-Propeller-QuickStart-Guide-v1.1.pdf
Also the Apllication note is located at:
http://www.parallax.com/sites/default/files/downloads/AN008-SigmaDeltaADC-v1.0.pdf
Some more information on Delta Sigma is at:
http://www.gadgetgangster.com/tutorials/382
Hope that helps to get you started.
Feel free to ask more questions.
http://forums.parallax.com/showthread.php/142052-Few-QuickStart-board-specific-questions
I will try Quick and Cheap: 1-Bit Sigma-Delta. I have a question.
In the circuit shown, how to connect input signal ?
Kaeru no Ojisan
Then sensor (+) / output goes to the pin above 'delta' (triangle), sensor (-) goes to the other.
If your sensor's ground / VSS signal is at a different potential than the QS board ground / VSS, this could cause problems and you'd need to buffer the signal before giving it to the Propeller.
Also, the gadget gangster schematic suggested resistor values, R1=100K and R2=150K, are for reading a 5v sensor. If you're reading a 3.3v sensor, you can use 100K resistors for both.
The Appnotes are kind of hard to find right now. I have them listed (with links) in post #3 of my index.
