Original Emic Connection — Parallax Forums
NWCCTVNWCCTV Posts: 3,629
edited 2014-06-16 08:18 in Propeller 1
Does anyone by chance have a schematic for connecting the original Emic device (http://media.digikey.com/pdf/Data%20Sheets/Parallax%20PDFs/30006.pdf ) to a Propeller BOE or Demo board? I have it connected to my Stamp HW board and it works fine. However, when I connect to my Prop BOE using the pin out configuration in the spin program it does not work so I obviously am ding something wrong.
    edited 2014-06-15 10:03
    Andy,
    Not looked a whole lot into it, but the EMIC is a 5 volt device. I'm sure you have the resistors in line with the Prop pins.
    Did you try Inverted and Non-Inverted?
    Do you have the code? Are you using FDS.spin?
    edited 2014-06-15 11:22
    This is what is in the comments of one of my emic demo programs.
    'Test of Emic text-to-speech module driver'Raymond Allen 2008
    'Public Domain
      '1.  Assumes both switches on the module are in the default, ON, position (see manual for details)
      '2.  Note that Emic is a 5V device!  Here's how I interfaced with proto board:
           'Vcc=+5V
           'GND=gnd
           '           +5VDC
           '             2kΩ          'Using a diode to get the voltage at Reset into the proper range
           'Reset  ────┫
           '            └ Pin7
           '         10kΩ
           'Busy   ───── Pin6     'Using resistor to limit current into Prop
           'SIN    ─────── Pin5     'From Prop
           '         10kΩ
           'SOUT   ───── Pin12     'Using resistor to limit current into Prop
    I hope the Parallax font show up better once I submit this reply than it looks now.
    The demo code I initially found uses a keyboard and TV. I'm pretty sure I have a version to use with a terminal window. I'll try to find it and post it.
    Unfortunately neither of my two original Emic devices work so I can't test the code.
    Edit: I think I may have changed some of the resistor values from the ones Raymond originally listed (the original values were too low).
    edited 2014-06-15 11:36
    This is the only example I found using a serial terminal. It compiles but I haven't tested it with an Emic. It looks like there is the beginning of code I added to use with a SpeakJet chip but it shouldn't cause a problem.
    The code uses an old version of a four port serial object. If you continue to use this code, you might want to switch to Tracy's new four port serial driver.
  • GenetixGenetix Posts: 1,775
    This might help:
    http://www.grandideastudio.com/portfolio/emic-text-to-speech-module/
    I would suggest contacting Joe directly and seeing if he has any Propeller code.
    Found this, but it doesn't say which version board.
    http://obex.parallax.com/object/62
    http://obex.parallax.com/object/63
