Has anyone a C code example for reading the BOE's ADC? (AD7993) — Parallax Forums
Alex.StanfieldAlex.Stanfield Posts: 198
edited 2014-06-13 23:07 in Propeller 1
I'm testing C waters with the BOE and needed an ADC driver.
Unless I missed something, the C learn pages are for the activity board which has a different ADC chip...
So if anyone has a working driver I'll be happy to learn from it.
Thanks!
Alex
PD: I found this thread (http://forums.parallax.com/showthread.php/142801-Anyone-have-examples-of-using-the-Prop-Boe-s-ADC-from-PASM) (see post #10) however I couldn't build it right away
  • dgatelydgately Posts: 1,643
    edited 2014-06-11 20:16
    Can't remember where or in what thread I got this code, but it looks for 2 versions of the Prop BOE's ADC chip...
    You'll need to mod the #if 0 to #if 1 to try several options to see what works for you.
    EDIT: Seems to be the same code from the previous thread... Builds for me with SimpleIDE. What kind of errors are you getting if it's not in fact building???
    /* ADC test program */
    #include <stdio.h>
    #include "i2c.h"
    #include "adc.h"
    #include "simpletools.h"
    int main(void)
        int i;
        int adcAddr;
        I2C *bus;
    #if 0
        if (!(bus = i2cBootOpen())) {
            printf("error: can't open boot i2c bus\n");
            return 1;
        /* check for the AD7993BRUZ-0 chip */
        if (DetectAdcChip(bus, AD7993BRUZ_0) == 0) {
            printf("AD7993BRUZ-0 found\n");
            adcAddr = AD7993BRUZ_0;
        /* check for the AD7993BRUZ-1 chip */
        else if (DetectAdcChip(bus, AD7993BRUZ_1) == 0) {
            printf("AD7993BRUZ-1 found\n");
            adcAddr = AD7993BRUZ_1;
        /* no adc chip found */
        else {
            printf("error: no adc chip found\n");
            return 1;
        for (i=0; i < 10; i++) {
            printf("%c", HOME);          // clear
            printf("adc[0] = %g\n", adcVolts(bus, adcAddr, 0));
           // printf("adc[1] = %g\n", adcVolts(bus, adcAddr, 1));
           // printf("adc[2] = %g\n", adcVolts(bus, adcAddr, 2));
            usleep(1000000);
    #else
        uint16_t  buffer[3*16];
        ADC       adc, *dev;
        uint16_t  newVal[2];
        uint16_t  oldVal = 0;
        if (!(dev = adcOpen(&adc, 28, 29, AD7993BRUZ_0, 7, 10000, buffer, 3*16))) {
            printf("error: can't open adc device\n");
            return 1;
        for (;;)  {
            uint16_t buf[3];
            adcRead(dev, newVal, 1);
            if (newVal[0] = oldVal) {
              printf("adc[0] = %d   old: %d",newVal[0] & 0xfff,oldVal);
              oldVal = newVal[0];
            //printf("adc[%d] = %d\n", (buf[1] >> 12) & 3, buf[1] & 0x0fff);
            //printf("adc[%d] = %d\n", (buf[2] >> 12) & 3, buf[2] & 0x0fff);
            usleep(100000);
            //printf("oPtr %04x, iPtr %04x\n", dev->state.mailbox.oPtr, dev->state.mailbox.iPtr);
    #endif
        return 0;
    dgately
  • Alex.StanfieldAlex.Stanfield Posts: 198
    edited 2014-06-11 20:22
    Thanks for that dgately!
    Would you be kind enough to pack the whole thing? adc.* i2c.* will be needed (possibly more than that) and I don't have a complete set for that.
    Thanks again!
    Alex
    edited 2014-06-12 05:08
    dgately wrote: »
    dgately
    Unpacking the file in the adc dir with no further modification; this is what I get
    Project Directory: C:/Users/PEST/Documents/SimpleIDE/adc/
    propeller-elf-gcc.exe -v GCC 4.6.1 (propellergcc_v1_0_0_2162)
    propeller-elf-gcc.exe -I . -L . -I ./include/ -I ./lib -Os -mlmm -Wall -m32bit-doubles -fno-exceptions -Dprintf=__simple_printf -c adc_test.c -o lmm/adc_test.o
    propeller-elf-gcc.exe -I . -L . -I ./include/ -I ./lib -o lmm/adc_test.elf -Os -mlmm -Wall -m32bit-doubles -fno-exceptions -Dprintf=__simple_printf lmm/adc_test.o ./lib/libi2c.a
    propeller-elf-gcc.exe: error: ./lib/libi2c.a: No such file or directory
    Done. Build Failed!
    Click error or warning messages above to debug.
    This is what I have on my project view
    The "lib" dir is not in the zip, neither is the "libi2c.a" file
    Alex
    Alex
    644 x 435 - 25K
  • ReinhardReinhard Posts: 489
    edited 2014-06-12 06:30
    Hi Alex,
    I have download adc.zip
    unfortunaly I have no Propgcc Toolchain around me yet.
    But I read the Makefile and it seems you have to build the adc_driver and i2c_driver first,
    then you can use the adc_test.side ...
    I try it later if I am at home
    Reinhard
    edited 2014-06-12 07:54
    Now it' s build.
    Can not test because I have not the hardware.
    cheers Reinhard
    adc.zip 60.3K
    edited 2014-06-12 08:55
    Here' a .zip of a SimpleIDE project that should build (includes libi2c library as well)...
    adcSimpleIDE.zip
    dgately
    edited 2014-06-13 17:05
    Thanks guys. I haven't checked in detail, but I had some trouble with one of the zips above and the code seemed to be re-reading the chip instead of converting and reading (output was fixed without any change) so I finally decided to digg into the AD7993 manual and build an ultra-simple routine, no libs required besides "simpletools"
    Here it is
     * This is the main ADC_BOE_test program file.
    #define uint8 unsigned char
    // ADC routines for BOE
    i2c *adcBus;                    // I2C bus ID
    uint8 adcAddr;                  // Address for this module
    uint8 addList[5]= { 0x20, 0x21, 0x22, 0x23, 0x24 }; //I2C bus addresses for ADC
    #define AD7993BRUZ_0    (0x21)  // Don't shift addresses, it's done by simpletools
    #define AD7993BRUZ_1    (0x23)  //
    // Init I2C bus and find/define the AD7993 address
    // Returns: 1=ok
    //          0=chip not found, address defaulted
    int AD7993start(unsigned int address) {
      uint8 i, t;
      adcBus = i2c_newbus(28,  29,   0);           // Set up I2C bus, get bus ID
      if (address == 0) { //Scan bus for AD7993 chips
        for (i=0; i<sizeof(addList); i++) {
          if (i2c_in(adcBus, addList[i], 0, 0, &t, 1) == 2) {
            adcAddr = addList[i];
            //printf("AD7993 found on 0x%X\n", adcAddr);
            return 1;
      } else {
        if (i2c_in(adcBus, address, 0, 0, &t, 1) == 2) {
          adcAddr = address;
          return 1;
      adcAddr = AD7993BRUZ_0;   //force address if everything else failed
      //printf("AD7993 defaulted to 0x%X\n",adcAddr);
      return 0; //return in error
    // Get ADC value for channel in binary form (0-1023)
    int AD7993in(int channel) {
      uint8 adcVal[2];
      i2c_out(adcBus, adcAddr, 1<<((channel&3)+4), 1,NULL, 0); //Set channel, mem ptr and start convert
      i2c_in( adcBus, adcAddr, 0, 0, adcVal, 2);           //Get 2 bytes from adc
      return ((adcVal[0] & 0xf) << 6) | (adcVal[1] >> 2);
    // Get ADC value in mV (0-5000)
    int AD7993inV(int channel) {
      return AD7993in(channel) * 5000 / 1023;
    int main(void) {
      uint8 i;
      pause(800);
      AD7993start(0);   //Init i2c bus and address
      while(1) {
        for (i=0; i<4; i++) {
          printf("ADC[%d]: %4d\t", i, AD7993inV(i));
        printf("\n");
        pause(500);
      return 0;
    Again thanks for your support.
    Alex
    Good for you, Alex!
    And thanks for responding with your code. I'll check it out!
    dgately
