Bug in Propeller tool software with the Documentation — Parallax Forums
TheDarkWraithTheDarkWraith Posts: 7
edited 2014-06-12 11:09 in Propeller 1
If you have something like the following:
PUB Test1
''this test does x
PRI Test2
''this test does x
PRI Test3
''this test does x
PUB Test4
''this test does x
And you switch to Documentation view the documentation comments for the first PUB block are shown and all the documentation comments for the PRI blocks that follow it appear in the first PUB block until the next PUB block is encountered. It appears the app doesn't stop 'adding' documentation comments until it reaches another PUB block
  • ksltdksltd Posts: 163
    edited 2014-06-11 14:03
    Exactly right - Documentation view shows the documentation to the clients of the object, not the implementors of it.
    edited 2014-06-11 14:11
    Not so. If that were the case, the comments for the private methods would not be shown at all. The OP is correct, and I have verified it: there does appear to be a bug in the doc view, since the comments for private methods do appear with their immediately-preceding public methods. Typically, all the private methods would be written after the public methods, in which case such a bug would be less apparent.
    edited 2014-06-11 16:31
    I don't think we should overcomplicate this. Double quotes apostrophes (line comment) do, single quotes apostrophes don't show up in documentation view. IOW, if you don't want it to be seen then style it accordingly.
    edited 2014-06-11 16:55
    I guess the solution is just to use single quotes in PRIvate methods, so the comments don't show up in the wrong place (i.e. don't show up at all).
  • TheDarkWraithTheDarkWraith Posts: 7
    edited 2014-06-11 19:53
    I was using double apostrophes not single quotes
    edited 2014-06-11 19:55
    Apologies, I meant apostrophes where I said quotes. Anyway, the point is that if you don't want comments to show up don't use double apostrophes, single ones will do just fine.
  • Jeff MartinJeff Martin Posts: 760
    It's hard for us to classify this as a bug... it's pretty much a feature but with this unintended side effect. Doc comments were not intended to be tied solely to methods, but were intended to show up in documentation view (as opposed to code comments) regardless of where they are in the source. In practice, it was intended that people don't write doc comments for anything they don't intend to be displayed in documentation view.
    But the case can be made that we should probably make this exception and just ignore doc comments inside of private methods.
    Here's my test code:
    PUB A
     'PUB A Code Comment (single line)
     ''PUB A Doc Comment (single line)
     {PUB A Code Comment (multi-line)}
     {{PUB A Doc Comment (multi-line)}}
    PUB B
     'PUB B Code Comment (single line)
     ''PUB B Doc Comment (single line)
     {PUB B Code Comment (multi-line)}
     {{PUB B Doc Comment (multi-line)}}
    PRI C
     'PRI C Code Comment (single line)
     ''PRI C Doc Comment (single line)
     {PRI C Code Comment (multi-line)}
     {{PRI C Doc Comment (multi-line)}}
    PRI D
     'PRI D Code Comment (single line)
     ''PRI D Doc Comment (single line)
     {PRI D Code Comment (multi-line)}
     {{PRI D Doc Comment (multi-line)}}
    PUB E
     'PUB E Code Comment (single line)
     ''PUB E Doc Comment (single line)
     {PUB E Code Comment (multi-line)}
     {{PUB E Doc Comment (multi-line)}}
    and here's my output (documentation view):
    Object "Untitled1" Interface:
    PUB  A
    PUB  B
    PUB  E
    Program:       8 Longs
    Variable:      0 Longs
    ______
    PUB  A
    ______
    PUB  B
    PUB B Doc Comment (multi-line)PRI C Doc Comment (single line)
    PRI C Doc Comment (multi-line)PRI D Doc Comment (single line)
    ______
    PUB  E
    This test reveals another problem... there's no new line after a multi-line comment being inserted into documentation view.
