Cleaner Way?
I am a second semester electrical and computer engineering major. I am fairly new to programming, about six months, and I have had some success getting this code to work. However, I would like to know if there is a neater way to write it. This is taken out of a project that I am working on. The entire project is just under 500 lines of code so I am just posting the section in question.
Please ignore the variables not declared in the function. They are global variables.
This is written using the simpleIDE compiler.
int main(){
int time, start, started, previous;
while(1)
previous = start;
start = get_state(22);
//start timer on rising edge
if((start == 1) && (start != previous) && (started == 0))
mstime_stop();
mstime_reset();
mstime_start();
started = 1;
//get time elapsed between previous rising edge and current rising edge
else if((start == 1) && (start != previous) && (started == 1))
time = mstime_get();
started = 0;
else
//convert time for one tooth cycle to revs per minute
//tweleve teeth per rev
float calc = ((60*1000) / (12 * time));
int rpm = (int) calc;
holder = rpm;
//change integrator time constant based on rpm
if( (rpm >= 8203) && (a != 0))
dataOut= 0b11000000;
spi();
a = 0;
else if( (rpm >= 7292) && (rpm < 8203) && (a != 1))
dataOut= 0b11000001;
spi();
a = 1;
else if( (rpm >= 6563) && (rpm < 7292) && (a != 2))
dataOut= 0b11000010;
spi();
a = 2;
else if( (rpm >= 5966) && (rpm < 6563) && (a != 3))
dataOut= 0b11000011;
spi();
a = 3;
else if( (rpm >= 5469) && (rpm < 5966) && (a != 4))
dataOut= 0b11000100;
spi();
a = 4;
else if( (rpm >= 5049) && (rpm < 5469) && (a != 5))
dataOut= 0b11000101;
spi();
a = 5;
else if( (rpm >= 4687) && (rpm < 5049) && (a != 6))
dataOut= 0b11000110;
spi();
a = 6;
else if( (rpm >= 4375) && (rpm < 4687) && (a != 7))
dataOut= 0b11000111;
spi();
a = 7;
else if( (rpm >= 4102) && (rpm < 4375) && (a != 8))
dataOut= 0b11001000;
spi();
a = 8;
else if( (rpm >= 3646) && (rpm < 4102) && (a != 9))
dataOut= 0b11001001;
spi();
a = 9;
else if( (rpm >= 3285) && (rpm < 3646) && (a != 10))
dataOut= 0b11001010;
spi();
a = 10;
else if( (rpm >= 2983) && (rpm < 3285) && (a != 11))
dataOut= 0b11001011;
spi();
a = 11;
else if( (rpm >= 2735) && (rpm < 2983) && (a != 12))
dataOut= 0b11001100;
spi();
a = 12;
else if( (rpm >= 2524) && (rpm < 2735) && (a != 13))
dataOut= 0b11001101;
spi();
a = 13;
else if( (rpm >= 2344) && (rpm < 2524) && (a != 14))
dataOut= 0b11001110;
spi();
a = 14;
else if( (rpm >= 2344) && (rpm < 2344) && (a != 15))
dataOut= 0b11001111;
spi();
a = 15;
else if( (rpm >= 2051) && (rpm < 2188) && (a != 16))
dataOut= 0b11010000;
spi();
a = 16;
else if( (rpm >= 1823) && (rpm < 2051) && (a != 17))
dataOut= 0b11010001;
spi();
a = 17;
else if((rpm < 1823) && (a != 18))
spi();
a = 18;
I take it you don't want to use the spi function unless the "a" variable is different this loop than the previous loop?
I think I'd add a local variable "newA" which gets set based on the rpm and this newA is then compared with a to see if there has been a change. IMO, this simplifies the code.
if (rpm >= 8203) { newA = 0; } else if (rpm >= 7292) { newA = 1; } else if(rpm >= 6563) { newA = 2; } // more else if else if (rpm >= 1823) { newA = 17; } else { newA = 18; } if (newA != a) { dataOut= 0b11000000 + newA; a = newA; spi(); }Does C not have "elseif"? (Apparently not.) My C is pretty rusty.
else if((rpm < 1823) && (a != 18)) { dataOut= 0b11010001; spi(); a = 18; }Suposed to be:
else if((rpm < 1823) && (a != 18)) { dataOut= 0b110100[COLOR=#ff0000]10[/COLOR]; spi(); a = 18; }If not, then the code I posted in post #2 will need to be changed.
Good catch on the bit pattern as well. I did not see that before.
