quesion about using a diode with 2 12v batteries
Thank you for taking the time to read my post.
So, what I am trying to do is connect two 12 volt batteries in series to give my motor more power.
The first 12v battery is apart of a circuit that is designed to be ran on 12 volts. I would like to connect this 12v battery to another 12v battery located further down my project to give my motor 24v.
I was thinking of running a diode in the line to prevent any possible back feed to the 12v circuits.
Im having a problem with finding the right diode, the batteries are 12v and 9.5 amps.
Try putting two little AA 1.5V batteries in series, and take some measurements at different locations, the results will surprise you.
It doesn't seem like it would work, but it does...
Go really crazy and put four AA batteries in series and see what happens...:thumb::thumb:
-Tommy
Edit- realized you said two batteries, one elsewhere in the chassis... so could do two 24's in parallel for longer run time.
I should probably tell a little more about what I'm doing.
I modified my son's power wheels. I added on a real turn key electric ignition switch. High beam headlights, low beam head lights, and a ground effects light kit, with a working radio. I am adding an adjustable speed control dial to keep the motors somewhere between 12 and 24 volts to make sure it isn't too fast.
I am worried that adding a second battery might blow the 12 volt lights
The only problem I can see would be with charging the batteries. Since battery A (the one already in the car) is supplying current for the motors and other systems while battery B supplies only the motor battery A will be more discharged than battery B. The batteries will need to be charged separately so both are fully charged, otherwise battery A may be damaged.
There are several on that infamous auction site ranging from under an Amp to over 20 Amps.
And don't skimp on the wire or terminal connections, use the heavy duty stuff if you can..
-Tommy
... and dielectric grease and heat shrink on all wiring connections, crimped or soldered, that may get wet. Murphy, of Murphy's Law fame has children too.
Probably want some transient and noise suppression on the system to protect the 12v side from back EMF from the motors when they start braking. If you can harvest that to recharge the batteries, even better... regenerative braking anyone?
