Trim disabled vs trim with 0 values
When i disable the trim function the robot drives almost straight (+- 0,5 cm).
But when i enable it the robot starts to curve to the right (around 5 cm), at the end it correct so it is pointing forward again. This even happens when all the trim values are 0.
This results are on a hard surface and over a distance of 90 cm.
Anyone have seen this effect before?
I would expect that both situations produced the same result.
I tested both versions 4-5 times, and the results where consistent.
This is the code with the trim enabled, this will move to the right.
This is the code with trim disabled, this will do +- 0,5 cm.
