4Dsysyems μlcd-43-pt priginal coding
Hi all,
I'm learning mechanical engineering at uni, a newbee for electrics, programming, neither μlcd for sure.
I'm keen to make it work with Engine controll unit (ECU)
Then I need some original codes to make them work on a real racing car.
From the ECU, there is streamline via RS232 but the data is not in order for the lcd to read, also no write obj command , nither checksum.
For example talking about RPM, there is RPM signal in fixed place.
So the thing I like to do is
1.Give proper codes to the lcd
2.Give the varuable info extracted from the ECU streamlone to the lcd
3.Give checksum to the lcd.
By the procedure above, I think the display works but I don't have clear idea for the codes.
Can anyone help me?
I will let you see the display work when it do well on our car.
Regards.
Can anyone help me?
Regards.
