LCD display that will run using only a maximum of 6 wires?
eagletalontim
I know there are hundreds of displays available on the market, but I am looking for a 2x16 black background and color font LCD display that is $15 or less at low quantities (10 and less) and can run directly from the Prop using 4 pins? Am I dreaming or is something like this available in the US?
It also must run from 5V as this is what my current circuit outputs. I can't change my circuit board to adjust to 3.3V since I have a bunch already ordered and on there way to me now.
How about with 3 Propeller pins and you provide a '595 piggyback?
http://www.electronics-lab.com/projects/mcu/015/
An awful lot are, but some are not.
Not sure.
Looking at the PDF, however casually, it looks much the same.
http://www.newhavendisplay.com/specs/NHD-0216K1Z-NSB-FBW-L.pdf
Some light reading --
http://www.eevblog.com/forum/beginners/lcd-hd44780-vs-splc780d-whats-the-difference-good-large-lcd/
I'm not so confident that the display I linked is truly white characters on dark background.
Sift through ebay, you may find an American-based seller that meets your price point.
