Set constant in object — Parallax Forums
prolowprolow Posts: 3
edited 2014-06-09 12:48 in Propeller 1
Is there a way to set a constant in a object from a method?
For example:
someObjWithConst.spin
CON
    bla = 0
TopLevelObj.spin
OBJ
    subObj : someObjWithConst
Pub
    subObj.bla := 6
  • JonnyMacJonnyMac Posts: 9,649
    edited 2014-05-30 23:54
    Contants, as their name suggests, cannot be changed.
    You can use a constant like this:
    foo := subObj#BLA
    You cannot use dot-notation to change variables inside constants, either; you must provide an interface method to make that change.
    edited 2014-05-31 04:29
    You can refer to constants in sub-objects as Jon showed, but a sub-object can't refer back to constants in the top object. I usually do something like this:
    TopObject.spin
    OBJ
      subObj : "SubObject"
    CON
      bla = subObj#bla
    SubObject.spin
    CON
      bla = 6
  • ksltdksltd Posts: 163
    edited 2014-06-09 11:02
    Declarations in CON sections are simply named numbers, and must be manifest constants. They have no representation at runtime. Therefore, there's nothing to change at runtime.
    edited 2014-06-09 11:16
    I often wish there were a way of setting constants in a child object based on a constant in the parent.
    Often a child object will have a buffer which needs to be sized to match a constant. It would be nice if these child objects could remain unchanged when these buffers are resized. As it is, I need a separate child object for each size of buffer a program needs.
    Serial objects are a good example of objects which would benefit from this sort of system.
    edited 2014-06-09 11:21
    In a case like this, the parent would provide the buffer and tell the child where it is and how big it is.
    edited 2014-06-09 11:24
    I sometimes go this route but it makes it harder to keep things modular. It would be really nice if there were a "#" type of notation which worked the opposite direction.
    edited 2014-06-09 11:45
    The way around this is to have a separate child object that has a dummy start method and, otherwise, just defines constants. Yeah, I know its awkward. Going the other way would require a construct something like this:
    CON
      sio#BUF_SIZE = 128
    But what if two objects do this to the same child, but with different values? The code and DAT portions of objects are shared amongst all instances. So there would be a conflict. I think Chip was right in not allowing "remote" CONstant definitions.
    I might start doing this with some of my projects but I was kind of thinking of objects to place in the OBEX where the person using the object wouldn't have to know much about how to set it up to use the object. Though it could be argued (probably correctly) setting constants used by the child in the parent is hardly modular.
    In these cases the compiler would need to keep separate copies of the object.
    I won't disagree. I'll have to find something else to whine about. Give me a minute and I'll come up with something.
