Reading multiple ADCs in parallel
I am looking into reading data from 21 different ADCs at once (MCP3008) and porting the data to a computer using the propeller. I was wondering how fast I would be able to read data from the 21 ADCs if I use one cog per 3 ADCs. Will it read as if there is 80MHz per ADC, or will it read like if I just used a single 80MHz microcontroller?
Also, what would be the best way to store the data before the 8th cog sends out all the data? I need to store the data from all 21 ADCs (168 channels, 12-bit frequency reading per channel) and send it out in one packet to a computer using USB. I want to keep the 8th cog open, so that it can port the data quickly.
I'm not using the ADC data directly. I am doing calculations in each cog to find the frequency of each channel, not the amplitude of the voltage. I was thinking about just using a byte to store the data, then have it write to a common variable array if the 8th cog is not currently sending out the data, but I am not sure if there is a way to make sure the USB communication remains uninterrupted.
The MCP3008 is the same as the MCP3208, but it has only a 10-bit precision. The SPI protocol is the same.
Any input would be appreciated.
How fast/often do you want to read the data from all the ADC's?
Do you want to read the data continuously or do you read in short bursts?
This is a 10 bit ADC so you will loose 2 bits if you store it in a byte. Do you only need 8 bit precision?
A better description of what you are trying to do will get you more help.
