Basic Stamp 2sx programming — Parallax Forums
Ben GrispenBen Grispen Posts: 7
edited 2014-05-26 17:01 in BASIC Stamp
Hello
Me and a friend are programming a robot with soms QTI sensors, 2 colorPAL's and a ping))) sensor, we need to follow a line and turn on a green mark.
We first used the Basic Stamp 2 but it was to slow. The robot wasn't riding smooth and stopped after a 2 seconds, so we bought a BS2SX, it is 2.5 times faster.
Now we changed our program to the specs of the BS2SX and uploaded it. The program still runs 2 seconds and 1 of the 2 colorPAL's doesn't work.
The BS2SX is also getting very hot, I don't think this is normal.
For programming we use subroutines for distance, colordetection and soms other functions, the main program is the linefollower. In the linefollower we call the subs.
Does somebody have any ideas what can be wrong of why it gets hot?
Thanks!
  • NWCCTVNWCCTV Posts: 3,629
    edited 2014-05-21 11:22
    A schematic and code example would help others help you out.
  • Ben GrispenBen Grispen Posts: 7
    edited 2014-05-21 13:28
    I'm sorry!
    This is something we tryed, this is also the first time we programmed, so the program can be a mess and the comments in the program are is dutch (sorry for this, we are from Belgium)
    This is the program: programma.txt
  • GenetixGenetix Posts: 1,775
    edited 2014-05-22 01:57
    I can only understand pieces of the program and I commented and fixed what I could.
    I can see some of the code comes from the Ping and ColorPAL sample programs as well as the Learn QTI projects.
    All of the servo commands are backwards because if you look at all the Boe-Bot programs you will see that the Servo on Pin 13 is always first.
    None of the times were adjusted since the BS2SX is 2-1/2 times faster than the BS2.
    There was a DO...LOOP inside of one of the subroutines.
    Another subroutine had a GOTO inside it which can cause the BS2 to crash. You never want to use a subroutine and not return from it.
    If you can explain what your program does or what it needs to do then we can help you with it.
    [code]
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    '===== Variabelen & constanten ========================================================================================
    ' Variables & constants (Dutch)
    constante CON 2260 ' Ping))) Constant (Echo time -> cm with **)
    ' Conversion constant for room temperature measurements.
    ' At sea level sound travels through air at 1130 feet per second.
    ' This equates to 1 inch in 73.746 uS, or 1 cm in 29.034 uS.
    ' 1 / 29.034 = 0.0344423779 (with **)
    ' 0.0344423779 * 65.536 = 2257.21567817 -> 2257
    ' The Ping))) returns a pulse width of 73.746 us per inch.
    ' The Ping))) returns a pulse width of 29.033 us per cm.
    PingTrigger CON 5 * 2.5 ' Ping))) trigger pulse = 10 uS (Added - 12.5 for BS2SX)
    ServoCW CON 650 * 2.5 ' Pulse Width for Full-Speed Clockwise (Added - 1625 for BS2SX)
    ServoLeft CON 700 * 2.5 ' Pulse Width to Curve Left (Added - 1750 for BS2SX)
    ServoStop CON 750 * 2.5 ' Pulse Width for Full-Stop (Added - 1875 for BS2SX)
    ServoRight CON 800 * 2.5 ' Pulse Width to Curve Right (Added - 2000 for BS2SX)
    ServoCCW CON 850 * 2.5 ' Pulse Width for Full-Speed Counter-Clockwise (Added - 2125 for BS2SX)
    PulseDodge CON 16 ' Number of 20 ms Servo Pulses Needed to Dodge (Added)
    PulseDetect CON 30 ' Number of 20 ms Servo Pulses Needed for Detecting (Added)
    PulseSearch CON 100 ' Number of 20 ms Servo Pulses Needed for Searching (Added)
    ' 122 ~ 3 sec, 61 ~ 1.5 sec, 244 ~ 6 sec, 407 ~ 10 sec, 41 ~ 1 sec
    Pulse90 CON 48 ' Number of 20 ms Servo Pulses Needed for a 90-degree Turn (Added - 24)
    a VAR Bit 'variabele a voor linker kleurensensor (Variable a for left color sensor)
    b VAR Bit 'variabele b voor rechter kleurensensor (Variable b for right color sensor)
    afstand VAR Word 'De afstand tot een object (Distance - The distance to an object)
    tijd VAR Word ' (time - Ping Pulse Time)
    roodL VAR Word ' (redL - Left ColorPAL)
    groenL VAR Word ' (greenL - Left ColorPAL)
    blauwL VAR Word ' (blueL - Left ColorPAL)
    kleurL VAR Word ' (colorL - Left ColorPAL)
    roodR VAR Word ' (redR - Right ColorPAL)
    groenR VAR Word ' (greenR - Right ColorPAL)
    blauwR VAR Word ' (blueR - Right ColorPAL)
    kleurR VAR Word ' (colorR - Right ColorPAL)
    teller VAR Word ' (counter - Number of Servo Pulses)
    ' I/O Pin Declarations
    Ping PIN 9 ' Ping))) Ultrasonic Sensor (Added)
    ServoRight PIN 12 ' Right Servo (Added)
    ServoLeft PIN 13 ' Left Servo (Added)
    sio1 PIN 14 'Seri
    edited 2014-05-22 06:08
    Code aside, getting hot is not normal. Check your wiring for shorts before your Stamp burns up. How much current is it drawing? Are you using the onboard 5v regulator?
    edited 2014-05-23 01:44
    Genetix wrote: »
    [code]
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    sio1 PIN 14 'Seri
    edited 2014-05-23 01:48
    We don't have shorts, we checked and double checked it! the BS2 isn't getting hot. The BS2SX draws +- 0.136 Amps, and yes we use the 5volts! The regulator is also getting hot! we use 9V batteries but they are in no time empty (10minutes)
    edited 2014-05-23 09:08
    I was given a used BS2SX that also gets hot (it shouldn't), it's useless. Maybe yours and mine suffered similar abuse early in their lives. If your BS2 is working properly, it sounds like you go back to using that. If you add a Servopal, your programming will get a lot easier.
  • 72sonett72sonett Posts: 82
    edited 2014-05-24 07:14
    ... The regulator is also getting hot! we use 9 V batteries but they are in no time empty (10 minutes)
    Do you run the servos on the same 9 V source as the BS2?
    edited 2014-05-24 09:14
    72sonett wrote: »
    Or worse, are you running your servos off of the board's regulated 5V? Ack!
    edited 2014-05-25 02:25
    Yes we do... but we also did it with the BS2 and that one worked for 30 minutes, our servos are connected to the on board servo headers (the 5v regulated voltage)
    edited 2014-05-25 02:30
    From http://www.parallax.com/product/900-00005;
    ...Do not try to power this servo directly from a BASIC Stamp module's Vdd or Vin pins; do not connect the servo's Vss line directly to the BASIC Stamp module's Vss pin.
    ... 1 of the 2 colorPAL's doesn't work.
    Did you swap them around to see if it is the ColorPAL itself or the hardware around it?
    Maybe this code does what you want to do;
    (%nnnn notation does not display correctly, I used %%nnnn)
    ' {$STAMP BS2sx}
    ' {$PBASIC 2.5}
    ' ===== Variables & constants ===============================================================
     true         CON 1
     false        CON 0
     leftisgreen  VAR Bit   ' left color sensor  Boolean
     rightisgreen VAR Bit   ' right color sensor Boolean
     distance   VAR Word    ' the distance to an object
     time       VAR Word    ' time - ping pulse
     red        VAR Word    ' red - from ColorPAL
     green      VAR Word    ' green - from ColorPAL
     blue       VAR Word    ' blue - from ColorPAL
     counter    VAR Word    ' general counter
                         ' I/O Pins
     pingpin    PIN  9   ' Ping))) Ultrasonic Sensor
     ServoRpin  PIN 12   ' Right Servo
     ServoLpin  PIN 13   ' Left Servo
     sio1pin    PIN 14   ' Serial in/output Left, ColorPAL #1
     sio2pin    PIN 15   ' Serial in/out Right, ColorPAL #2
     baud       CON  33095  ' Baud Rate for ColorPAL, 7200 Baud, 8-bit/no-parity, True, Open)
                            ' 327 + 32768 = 33095, ColorPAL Baud Rate for BS2SX
     QTIs       VAR Nib  ' Black/white line data from QTIs
    ' ===== Main program =======================================================================
     GOSUB init           ' initialise everything that needs to be initialised once
     DO                   ' Main program loop
       GOSUB getcolors    ' determine if left/right is green, then turn left or right or detect & turn towards bottle
       GOSUB followline   ' otherwise follow black line
     LOOP                 ' forever
    END
    ' ===== Subroutines =========================================================
    init:
       ' Reset colorpals:      Sends a long break to reset ColorPALs and enter direct command mode.
       LOW sio1pin             ' make serial I/O low so residual voltage fully disappears
       INPUT sio1pin           ' Set serial I/O back to input
       DO UNTIL sio1pin : LOOP ' Wait until the Colorpal sets the pin high
       LOW sio1pin             ' make I/O pin low
       PAUSE 80                ' Hold the pin low for 80 ms to switch to direct mode
       INPUT sio1pin           ' Set I/O pin to input
       PAUSE 10                ' Wait another 10 ms
       LOW sio2pin             ' same for colorpal 2
       INPUT sio2pin
       DO UNTIL sio2pin : LOOP
       LOW sio2pin
       PAUSE 80
       INPUT sio2pin
       PAUSE 10
       OUTB =%%1111            ' initialise QTIs
    RETURN
    getdistance: ' Range finder - ping), returns distance in cm in variable "distance"
       PULSOUT pingpin, 5         ' activate sensor (trigger pulse = 10 uS)
       PULSIN  pingpin, 1, time   ' measure echo pulse
       distance = pingconstant ** time
    RETURN
    check_QTIs:  ' 4 infrared emitter/receivers differentiate between a dark and a light surface
                 ' 0 =  white surface, 1 = black.
    ' P7 -  Far Left, P6 - Mid Left, P5 - Mid Right, P4 - Far Right
      DIRB = %%1111 ' P7..P4 all output
      PAUSE 1      ' Delay = 1 msec (let the capacitors discharge)
      DIRB = %%0000 ' P7..P4 all input
      QTIs = INB   ' Save QTI outputs
    RETURN
    followline:
      GOSUB check_QTIs              ' get black line data from QTIs
      SELECT QTIs
        CASE %%1000                  ' Line is on the far left; turn left towards line
          PULSOUT servoRpin, 650
          PULSOUT servoLpin, 650
        CASE %%1100                  ' Line is to the left, veer left
          PULSOUT servoRpin, 750
        CASE%%0100                  ' Line is to the mid left
          PULSOUT servoRpin, 800
        CASE %%0110                  ' Line is in the center, straight ahead
          PULSOUT servoRpin, 850
        CASE %%0010                  ' Line is to the mid right
          PULSOUT servoLpin, 700
        CASE %%0011                  ' Line is to the right
          PULSOUT servoLpin, 750
        CASE %%0001                  ' line is to the far right, turn right towards line
          PULSOUT servoLpin, 850
        CASE ELSE                  ' No line, try to find it
          DO WHILE (Qtis = 0)      ' No Line Detected
            PULSOUT servoRpin, 850 ' Veer right [Pivot Left Backwards]
            PULSOUT servoLpin, 750 ' Full-Stop
            PAUSE 20
            GOSUB check_QTIs       ' keep trying
          LOOP
      ENDSELECT
      GOSUB getdistance  ' Measure the distance to an object (bottle) with PING)) range finder
      IF (distance <= 16) THEN   ' object is too close, avoid it
        FOR counter = 1 TO 16    ' 90-degree Left Turn
          PAUSE 20
        NEXT
      ENDIF
    RETURN
    getcolors:    ' obtain RGB data from ColorPALs and determine if green
      'left side ColorPAL
      leftisgreen = false   ' reset color left side
      SEROUT sio1pin, baud, ["= (00 $ m) !"]
      SERIN  sio1pin, baud, [WAIT("$"), HEX3 red, HEX3 green, HEX3 blue] ' Get the RGB data from the sensor
      IF ((red + green + blue) <= 300) THEN leftisgreen = true
      'right side ColorPAL
      rightisgreen = false    ' reset color right side
      SEROUT sio2pin, baud, ["= (00 $ m) !"]
      SERIN  sio2pin, baud, [WAIT("$"), HEX3 red, HEX3 green, HEX3 blue]
      IF ((red + green + blue) <= 300) THEN rightisgreen = true
      IF (leftisgreen = true)  AND (rightisgreen = false) THEN GOSUB turn90L ' if only left side detects green, turn 90 deg left
      IF (leftisgreen = false) AND (rightisgreen = true)  THEN GOSUB turn90R ' if only right side detects green, turn 90 deg right
      IF leftisgreen AND rightisgreen THEN GOSUB object_detection ' if both sides detect green; look for bottle
    RETURN
    turn90L:                     'Turn 90° to the left  (reel off - Left)
      FOR counter = 1 TO 48
        PULSOUT servoRpin, 700
        PAUSE 20
      NEXT
    RETURN
    turn90R:                     ' Turn 90° to the right  (reel off - Right)
         PAUSE 20
       NEXT
    RETURN
    object_detection:
      FOR counter = 1 TO 30       ' 90-Degree Left Turn?
        PULSOUT servoRpin, 650    ' Turn to the Left ?-degrees
        PAUSE 20
      NEXT
      GOSUB getdistance           ' get start value
      DO WHILE (distance > 45)   ' Keep turning right until the object is <= 45 cm
        PAUSE 15
        GOSUB getdistance
      LOOP
      FOR counter = 1 TO 2        ' Slight right turn
        PAUSE 15
      NEXT
      FOR counter = 1 TO 100      ' Back-Up for a few seconds
        PAUSE 20
      NEXT
    RETURN
    edited 2014-05-25 10:20
    Nonetheless, you may have blown your regulator in those 30 minutes. Each servo can draw over an amp, and that regulator may be toast. If it worked then but it doesn't now, you may have answered your own question. Unplug your servos from the board entirely and run your Stamp alone for a while on the 9V. First see if it works, then see if the reg still overheats.
    If you're a lucky fellow, both your Stamp & reg survived and all you have to do is add a separate battery for your servos. But if you killed your board's 5V regulator, you'll also have to add a separate 5V regulator, connection that to Vdd and not using Vin. Never feed anything but 5.000000V to Vin or you can kiss your $50 BS2 goodbye.
  • SapphireSapphire Posts: 497
    edited 2014-05-25 18:41
    I think you mean Vdd, not Vin. Vdd can safely be between 4.5v and 5.5v.
    edited 2014-05-25 19:26
    Sapphire wrote: »
    Thank you, Sapphire, I maid another missteak. :)
    Yes, you're correct, Vdd is what I meant. It's the sensitive one which dearly loves 5 volts.
    edited 2014-05-25 22:19
    As soon as I noticed the BS2SX was getting hot, I switched back to the BS2 and this one stays cold, also the regulator stays cold. And we never changed the jumper to Vin, it's still jumped to vdd, but the headers on the board of education are meant the be used for servo's...
    edited 2014-05-25 22:22
    72sonett wrote: »
    ' {$STAMP BS2sx}
    ' {$PBASIC 2.5}
     true         CON 1
     false        CON 0
                         ' I/O Pins
     LOOP                 ' forever
    END
    init:
       INPUT sio2pin
       LOW sio2pin
       PAUSE 80
       INPUT sio2pin
       PAUSE 10
    RETURN
    RETURN
    RETURN
    followline:
      SELECT QTIs
            PAUSE 20
          LOOP
      ENDSELECT
          PAUSE 20
        NEXT
      ENDIF
    RETURN
      'left side ColorPAL
    RETURN
        PAUSE 20
      NEXT
    RETURN
         PAUSE 20
       NEXT
    RETURN
    object_detection:
        PAUSE 20
      NEXT
        PAUSE 15
        GOSUB getdistance
      LOOP
        PAUSE 15
      NEXT
        PAUSE 20
      NEXT
    RETURN
    Yes I did, nothing is wrong with the hardware, I can switch the wires and the sensor on the same pin ist working. The sensor on pin 14 workd and on pin 15 doesn't.
    Yes (and that's different from the Stamps' on-board 5V.) The two are kept separated on the BoE, that servo 5V comes from a regulator located on the BoE.
