Help with 16-Segment Displays on Pro Dev Board
Entomy
I think I must be mentally deficient in this area or something. I've gotten nearly everything else working fine, and understand why it works. But I'm completely confused by the 16-Segment displays. I don't seem to understand how to wire them. I checked the manual for this board, but I guess I don't understand what the letters for the pins mean, or something. Any help or explanations? Thanks in advance!
By setting the segments you want lit high you can have these segments show up on the digit you want by only setting the desired digit pin low. The digits you don't want lit will have their cathodes held high.
My cycling through each digit one at a time, quickly, you can make the display show any combination of segments you wish. The Propeller can easily cycle through the digits fast enough that they shouldn't appear to be turning on and off.
I'm pretty sure there are enough I/O pins on the Propeller for the Propeller to drive the display directly. However if you want to use some pins for other purposes, you'll want to use a some sort of shift registers to control the display.
The 74xx595 shift registers work great for driving the display. TonyP made a small PCB with '595 chips which works great for this purpose.
Each letter on the "SEGMENTS" connector corresponds to its segment.
http://forums.parallax.com/showthread.php/134106-Updated-17seg-LED-driver-for-PPDB-now-available.
It seems like every segment except A2 works; why would this be? Connecting it to any pin does not work, even if that pin drives other segments just fine. The A2 on every segment does not work, which is extremely strange to me.
Any ideas, because I'm fresh out?
What is the "supplying segment"?
If connecting to A2 is causing other segments to turn off, it may be you have a short on one of the A2 solder joints. The A2 pin is the top right (looking from the top of the board) pin of each display module. Take a look at the back of the board and make sure the solder on this pin isn't touching the ground pour on the bottom of the board. Most of the copper on the bottom of the board is connected to ground. If a solder joint is too large, it can end up shorting to ground.
How to the solder joints of the A2 pins look?
Edit: You may need to move the black rubber foot to inspect the A2 pin of the far right display module.
Edit again: Where did you get this board? If you purchased it from Parallax recently you may be able to exchange it. Though I think it's a shame to exchange it if it can be easily fixed.
I believe I may have found the problem, but need to pick up a new meter to be sure. It looks like at some point, a small part of bluish coating came off, exposing the copper, which the solder seems to be touching. Even without the meter, I'm near certain this is the problem, as it explains what I've been seeing perfectly. I ordered the board through Amazon, but the seller was Parallax. If I'm right though, I can easily fix this problem.
I think the way boards are soldered in a factory requires the solder mask to be intact. I think any exposed metal gets soldered. I think they call it "wave soldering" since the boards pass over a standing wave of molten solder.
Solder wick makes removing excess solder really easy. You can probably fix the problem without solder wick but if you'd like to try it, send me a PM with your address and I'll mail a foot of it for you to try.
Solder wick is great stuff to have on hand. It's really useful when soldering surface mount parts. Just glob the solder on to the leads and suck the extra off with solder wick. You'll wonder how you ever got along without out it (assuming you don't already use it).
Parallax is really good about replacing defective parts but I always hate to send a board back if it's easy to fix it myself.
I hope you let us know how this turns out.
I do know about solder wick, and have plenty myself. :P Thanks for your kindness though; I'm sure it's been much appreciated by others. I'm very comfortable doing programming, and pure electrical circuits, but have never mixed the two for embedded/uC applications. I spent a lot of time trying to find a suitable platform. The big thing I didn't want a desktop style processor, just scaled down, which many seem to behave like. I've been very satisfied with the Propeller, Spin, and this board. The community seems great so far too.
Thanks to those who've helped, it's been much appreciated.
That's good news!
That's unusual because Parallax has a great history of quality workmanship.
Please visit here often.
Jim
Even while inspecting the board under x40 magnification, the workmanship was impressive. I had originally expected poorer quality, as the price of this board is nowhere near many professional dev boards for things like the PIC, MIPS, et al. Oh how foolish that seems now. I'm very impressed by this thing, in price, quality, design, and utility. With the crappy quality of many goods nowdays, I expect to have to fix several things; fixing only one simple issue is a nice change. I definitely feel like I made the right choice in microcontrollers to learn and work with.
